HDPE Main Water Line Leak Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2010, 02:49 PM   #1
Unhappy
HDPE main water line leak repair
What are the most reliable way(s) for a DIY'er to repair a leak in an HDPE water main line?
I'm currently trying to splice a length of HDPE tubing using stainless steel barbed connectors and hose clamps. The first connection is good and doesn't leak, but the second connection is leaking quite a bit, even at much reduced water pressure. It was very difficult for me to insert the last connection and get the barbs into the tubing far enough (I was using a heat gun to heat the tubing, but no lubricants). Is there a lubricant that's ok to use in the water supply? Or is there another way or trick to do this that's easier ?
Thanks in advance,
Karen
justgetitdone is offline   Reply With Quote
Old 09-24-2010, 05:31 PM   #2
Rewards Points: 150
Heat is the only thing I've ever used, you may not be getting them hot enough, I always use two hose clamps on each joint counter opposed to each other
braindead is offline   Reply With Quote
Old 09-24-2010, 07:46 PM   #3
Thanks...I'm now trying brass male threaded barbs and a PVC union so that I don't need so much leverage to make the final connection...In order to redo I had to take out more PE, so I have more splices than I'd like, but I just want to be able to turn my water back on even if there are some temporary leaks.
Old 09-24-2010, 09:48 PM   #4
I always take a torch and heat the poly a bit so it's soft and bites the barbs well. Helps get it on easier too. Like someone said above, 2 hose clamps that aren't way too big with the screw on opposite sides
the_man is offline   Reply With Quote
Old 09-25-2010, 07:04 PM   #5
The PVC union did not work as it is too rigid and there's a bit of a bend needed in the repair area. So went back to the barbed connectors, double hose clamps and heated the PE more and it worked...with no leaks (yet anyway)!
I was able to use my 1875W hairdryer which did heat up the PE enough to get the barbs in and make a good seal.
Thanks "braindead" and "the man" for your replies and help.
Tags
hdpe pipe repair , water main leak
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Best method to repair leak in main supply (PVC) vintagewolf Plumbing 7 08-03-2010 09:35 PM
How to shut off main hot water line? AlexnNotHandy Plumbing 7 10-12-2009 10:14 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
