Having Trouble Getting A Tub Spout Back On - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2010, 07:18 PM   #1
Question
having trouble getting a tub spout back on
Yesterday I removed a bathtub spout because there was a gap between the spout and the wall and I wanted to clean it up and reapply the silicone chalk. I applied silicone tape to the copper and have not been able to get the spout back on. This spout dates back to 1980 and is the screw on type. I also went to Home Depot and bought a new spout but can't get it on either. Any ideas?
rkFrisco is offline   Reply With Quote
Old 09-12-2010, 07:26 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you mean Teflon tape (or PTFE, same thing)?
how many wraps of tape did you put on? If you applied too much, it could be that you simply cannot get the pipe end to fit into the spout far enough to get a thread started.
Old 09-12-2010, 08:16 PM   #3
Twice around "with tension" on the tape.
Old 09-12-2010, 08:17 PM   #4
Yes, with teflon tape.
Old 09-12-2010, 08:18 PM   #5
nap
You talking to me?
nap's Avatar
well, it's not too much but...
try removing the tape and trying the spout. If you can get it on without any tape, you just aren't getting a thread to catch. After you reapply the tape, when trying to install it, push inward with force as you turn the spout.
The Following User Says Thank You to nap For This Useful Post:
rkFrisco (09-12-2010)
Tags
bathtub spout problem , spout question
Can a concrete truck get into my back yard? J S Machine General DIY Discussions 55 05-22-2010 01:11 PM
Tub, Separating valve and spout bigmatt Plumbing 0 02-05-2010 04:23 PM
GFCI in the bathroom trouble canyonbc Electrical 7 01-26-2010 03:36 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
HELP ! trouble putting belt back on Kenmore elec. dryer ! jays_gyrl1027 Appliances 2 09-17-2008 07:16 PM
