Have You Heard Of Codes Like This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2013, 11:02 PM   #16
Lord of Slums
Rewards Points: 1,974
http://www.simivalleyacorn.com/news/...unity/004.html As if we needed one more reason not to use a bigbox
mj12 is offline   Reply With Quote
Old 12-19-2013, 11:03 PM   #17
Rewards Points: 1,002
Originally Posted by TheEplumber View Post
And I pretty much agree. some code updates should be enforced. others not so much.
I'll say it again, perhaps another plumber is needed.
There are people out there that attempt to upsell.....
I was mainly warning that the "bring it to code" spiel is mostly used by tradesmen needing additional work and home inspectors.
Anti-wingnut is offline   Reply With Quote
Old 12-19-2013, 11:11 PM   #18
Rewards Points: 6,652
I am so glad what my area does not require this nonsense.
Now getting back on topic. The so called repair person and company should be reported to your state AG, for trying to take advantage of the customer, due to they saw her as an illinformed female, even though it appears that she did not take one bit of their story as the truth.
I bet if you did some digging, you may find this so called repair person new in the industry. A good friend of ours went through a ASE mechanic of a very old family car repair business in our town, trying to pull the scam of "You need a new air filter, this one is black and clogged, you have some severe leaks" attempt.
That person is no longer an employee of this business, since the owner does not run their company that way.
Old 12-19-2013, 11:15 PM   #19
Actually more by non-licensed people in the trade, new people staring, those that are just pure scum.
They usually do not last long after word gets out. In my town of even 117k, with a county populace of close to 200k, the scam artists do not get away with it, and the companies put out the fire from the repercussion real quick.
Old 12-20-2013, 08:27 PM   #20
Now, now....I'm a licensed Home Inspector in NH (thus checking codes constantly). Home inspectors aren't code enforcers, and in fact if we are not 110% sure that the code we are calling is correct...we have to report something to the effect of: "this ______ does not seem to be up to industry standards."
I did call the Merrimack building office today and they explained that the NH code is the code they use, there is no local code. The codes have not changed since 2009 (the plumber told her new code changes happened at the beginning of the year). They seemed pretty interested in finding out who this guy is. I'm not a rat, but don't mind putting a scare into an unethical contractor.
neight is offline   Reply With Quote
The Following User Says Thank You to neight For This Useful Post:
gregzoll (12-20-2013)
Old 12-20-2013, 08:54 PM   #21
Rewards Points: 1,684
Few localities require a permit for a water tank replacement
All areas of Ohio that have a plumbing inspector always inspect replacement installs of hot water tanks. It also can only be done by a licensed plumbing contractor or a home owner himself on a home owner permit. You are also required to bring it up to current code. And permits are required. It's only 45 dollars.
Usually the only major difference is the addition of a leak pan and a drain if the basement was finished since the original install. Professional plumbers already know this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
JDC (12-22-2013)
Old 12-22-2013, 09:55 PM   #22
Master Plumber
Javiles's Avatar
Rewards Points: 984
code or no code common sense should tell you if there have been changes to the code its for a reason mainly safety. why not do them while your at it. as for not requiring a permit, i cant see any state or municipality letting a home owner or handy man install a water heater one that fires with gas two omits gases from a burner to a flew.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
code , hot water heater , plumbing
Error codes clklt Plumbing 6 05-05-2013 07:17 PM
all building codes followed? LynnX HVAC 1 02-24-2013 04:56 AM
Deck Building Codes ashleyripka Building & Construction 18 12-02-2012 08:13 PM
Trying to finding building codes for HVAC rvmeush HVAC 7 09-29-2012 10:38 AM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 08:15 AM
