Have You Heard Of Codes Like This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2013, 07:47 PM   #1
Have you heard of codes like this?
A friend of ours had her hot water tank serviced and the plumber explained that to be up to code she needed to add a sprinkler head (because the tank is too close to a wall without sheetrock) and a Floodmaster for the drain pan. I agree with the other code upgrades that he mentioned, like the expansion tank and better ventilation. However, I have yet to come across codes like this and I do check codes regularly. This may simply be a city code, but seems excessive to me. Anybody have these codes where they live? Thank you.
-Nate-
neight is offline   Reply With Quote
Old 12-19-2013, 08:20 PM   #2
Rewards Points: 1,772
-Nate-
Nate
Did your plumber pull a permit for the job?
Call your local building department and ask.
The Following User Says Thank You to Ghostmaker For This Useful Post:
neight (12-19-2013)
Old 12-19-2013, 08:53 PM   #3
I don't know if he pulled a permit, but will ask her to call the building department. Unfortunately, it seems the wheels were already turning when I heard of this. I guess he was starting the job this afternoon.
Old 12-19-2013, 08:59 PM   #4
Rewards Points: 1,002
He should be fired tonight. There is no need for a remove and replace of an existing appliance which was installed as per an earlier code to meet todays code. A remove and replace only needs to meet the codes of the original installation.
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
gregzoll (12-19-2013)
Old 12-19-2013, 09:05 PM   #5
Originally Posted by Ghostmaker View Post
Nate
Few localities require a permit for a water tank replacement
Old 12-19-2013, 09:23 PM   #6
I didn't mention this, because I haven't seen what the gas line is, but he also said that needed to be upgraded too. My house was built in the 50's and I have iron pipes for natural gas...her house is probably around the same age if not newer.
Old 12-19-2013, 09:30 PM   #7
Nashua NH requires a permit and a licensed gas fitter to install hot water heaters. Actually, you can't even buy a hot water heater fitted for gas without being licensed...tried that. Merrimack isn't but a stones throw from here, so my guess is they have the same ordinance.
Old 12-19-2013, 09:52 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 452
Idaho and Washington require permits for water heaters as well although a lot are installed without.
My city also now requires carbon monoxide detectors for WH replacements inside a home, and expansion tanks, and pans, and........... no wonder permits aren't pulled.
In your case- look for a new plumber
Old 12-19-2013, 10:19 PM   #9
I always suggest the basics: pans, CO detector, expansion tank, proper shut offs, ventilation...we paid around $1200 2 years ago when ours went and that was a full upgrade to code, expansion tank included. I'm most concerned about our friend getting ripped off.
Old 12-19-2013, 10:32 PM   #10
Do you have a citation for your claim about Washington?
Page 3
Plumbing fixtures, including water heaters, do not require a permit when replacing like for like.
Snohomish County (Washington State USA) FAQ's Planning and Development Services
http://www.co.snohomish.wa.us/docume...0quest0706.pdf
All other locations in Washington that I am aware of in my not insubstantial career are similar. But I sure would like to see the RCW your quoting.
Old 12-19-2013, 10:43 PM   #11
Page 3
How about we pay attention to the task on hand...we don't need a pissing contest here. codes change from state to state, county to county, city to city. All follow the IRC or IBC as a base and build off that as they see fit.
Old 12-19-2013, 10:50 PM   #12
Plumber
Rewards Points: 452
Page 3
I know where Snohomish Co is. I used to live in Bothell
I don't have in front of me a code reference except that the UPC code book ly says (paraphrased) "any fixture replacement requires a permit". Washington uses UPC. Of course- cities, counties, etc. can amend it.
a couple years ago the company I was with had installed 3 gas water heaters in an apt. complex over the course of a year. They had to go back and pull permits, pay double fee and have them inspected. The property manager had also installed some electric WH's He too was fined-- City of Spokane WA
Oh, and 1 of the gas heaters failed due to bonding issues
Old 12-19-2013, 10:52 PM   #13
I was on task. I was questioning the need for the plumber to bring it to modern code. I don't think the HO is compelled to do so legally
Old 12-19-2013, 10:57 PM   #14
Plumber
Rewards Points: 452
And I pretty much agree. some code updates should be enforced. others not so much.
I'll say it again, perhaps another plumber is needed.
There are people out there that attempt to upsell.....
Old 12-19-2013, 11:01 PM   #15
I remember when Bothell was only in KingCo, now it's in both counties.
Tags
code , hot water heater , plumbing
Error codes clklt Plumbing 6 05-05-2013 07:17 PM
all building codes followed? LynnX HVAC 1 02-24-2013 04:56 AM
Deck Building Codes ashleyripka Building & Construction 18 12-02-2012 08:13 PM
Trying to finding building codes for HVAC rvmeush HVAC 7 09-29-2012 10:38 AM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 08:15 AM
