Have You Ever Thing This Bath Faucet Stem? Very Rare. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2010, 05:24 PM   #1
Have you ever seen this bath faucet stem? Very rare.
My bathroom faucet is leaking a bit of water and would like to take out the stem (or diverter) and replace the washer. However, I don't know how to remove the stem since it doesn't have the regular hex socket head. The rest of the fixtures are from a company named "Harden" which I understand is no longer in business. I have attached three pictures. The front of the stem is made of gray plastic.
Please help!
Have you ever thing this bath faucet stem?  Very rare.-img_1small.jpg   Have you ever thing this bath faucet stem?  Very rare.-img_small2.jpg   Have you ever thing this bath faucet stem?  Very rare.-img_small3.jpg
allen_91107 is offline   Reply With Quote
Old 08-15-2010, 05:31 PM   #2
Owner
LateralConcepts's Avatar
I would say it's time to update. Replace the entire tub/shower valve. Consider tile while you're at it.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-15-2010, 05:37 PM   #3
That would be nice. But not in the budget. I am sure it is a simple washer issue if I can get to it.
Old 08-15-2010, 05:45 PM   #4
Owner
Not sure. I've never seen one like that. Perhaps someone else here will know.
Lateral
(208) 818-8241
Old 08-15-2010, 09:43 PM   #5
I've seen these once or twice, i've ordered parts from some company in the seattle area that makes them aftermarket. the brass part behind the handle stop will unscrew, it just looks different from a standard Price Pfister stem or similar. I googled for pics for ya, found an old thread off of this forum that shows it a little more dismantled... Harden faucet stem removal once you get to this point, you should be able to slide the handle back on and gently unscrew it from the valve body, just like when you turn it on
the_man is offline   Reply With Quote
Old 08-15-2010, 10:21 PM   #6
Thanks for the reply. I actually did see the tread in your link before I posted mine. The stems are a bit different. On mine, there is no hex nut at all. The beginning part is plastic. I think what I am going to do is to put in a shutoff valve going to the valve body so I can take the plastic piece out without shutting off the water to the whole house.
Old 08-16-2010, 09:54 AM   #7
Not a bad idea, you can never have enough shut off valves in the house. If you're going to be opening up the wall behind to do that, consider installing a new valve like lateral concepts said. Lowes/Depot have a Moen double handle for like 80 bucks, as long as the valve that you have now is on 8" centers it should fit in pretty easily. You'll spend a lot of time/gas looking for parts for that faucet and who knows if you even will find anything other than washers.
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 07:38 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
