Have You Ever Seen This Hose? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 07:16 PM   #1
have you ever seen this hose?
This is attached to my Danze Sirius wide spread faucet. When i originally installed the faucet i had to do some minor "alterations" in order for the faucet to fit properly. Now both the hot and cold lines blew and I have no clue where these hoses came from. I contacted Danze directly and they say theyve never seen them. Anyone out there have a clue where I can possibly find replacements?
tried google to no avail
wojjow is offline   Reply With Quote
Old 07-25-2012, 08:27 PM   #2
Rewards Points: 582
save yourself alot of trouble replace the faucet...danze is not worth it...
Old 07-25-2012, 09:03 PM   #3
Its worth more than your pointless opinion. Ive had a faucet and a tub set from them for more than 4 years without a single problem, except for some hoses which weren't even from them
Old 07-25-2012, 10:25 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 814
Save yourself some grief, replace it👍
Sent from my iPhone using DIY Forum
Old 07-25-2012, 10:39 PM   #5
Seems like I have seen hoses like these running to an ice maker, possibly used as supply lines to a sink. Pretty sure lowes or home depot carry them
jstring3 is offline   Reply With Quote
Old 07-26-2012, 09:25 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Well, that's pretty rude, considering i'd say the same thing the other two plumbers both said.
If that faucet is made and sold by Danze, and you called them, and they said they've never seen such a part, I'd chalk that up to terrible customer service, and throw the faucet in the garbage.
Sorry if you want to save the faucet, but a lot of cheaper faucets use a similar style of supply line. You're not going to be able to get those anywhere but from the manufacturer. Even if you buy another cheap faucet and try to steal the supplies from it, chances are that they are a different thread pattern.
Best of luck on all your future endeavors,
-Alan
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (07-26-2012), rjniles (07-26-2012)
Old 07-26-2012, 12:26 PM   #7
Rewards Points: 582
well my opinion is still better than the opinion your direct contact with supplier had....fyi my comment was based on the supplier comment....if they can't help you ..THE FAUCET IS NOT WORTH IT....
Old 07-26-2012, 05:03 PM   #8
Rewards Points: 150
From reading the installation instructions for your faucet, the standard hose connection screws into your faucet. The double o-ring connection connects into your plumbing. So you don't need to replace the faucet, you need to replace the non-standard fitting or valve that is connected to your plumbing. Then you can get a standard braided hoses at any store including the dollar store if so inclined.
goosebarry is offline   Reply With Quote
Old 07-26-2012, 08:45 PM   #9
Doing it myself
Alan's Avatar
the non standard connection is at the faucet.
Journeyman Plumber
Old 07-26-2012, 09:52 PM   #10
This thread had me cracking up from the beginning. Thank you all for making me laugh so hard
JadRutherford is offline   Reply With Quote
Old 07-26-2012, 09:54 PM   #11
Rewards Points: 582
other way around...
Old 07-26-2012, 10:10 PM   #12
Missouri Bound's Avatar
The brass looks like standard compression fitting. Should be easy enough to take to a plumbing supply house or a good hardware store and say "I need to replace this" It's not rocket science just oddly plumbed. Use braided lines to replace the tubing, preferably stainless.
Do you want it your way or the right way?
Old 07-27-2012, 12:16 PM   #13
Rewards Points: 150
other way around...
1) The vendor doesn't recognize the connection.
2) It doesn't agree with their installation manual.
3) Blew out after only 4 years.
I have to agree. I would replace the faucet.
The Following User Says Thank You to goosebarry For This Useful Post:
ben's plumbing (07-27-2012)
Old 07-27-2012, 04:19 PM   #14
Rewards Points: 582
I installed delta faucets in my house 22 yrs ago....still work and can still get parts... standard parts....THAT IS SERVICE.....not 4yrs at which supplier can't help you.....i stand by my comment replace your faucet with anything but danze....
The Following User Says Thank You to ben's plumbing For This Useful Post:
plumberinlaw (07-27-2012)
Bathroom Vent Hose Setup incufilter Plumbing 6 11-16-2011 09:58 AM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 12:18 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
