Have To Use A Plunger After Every Bow Movement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2009, 09:48 PM   #1
Have to use a plunger after every bow movement
Every time anyone in my home has a bow movement in our newly installed trovani toilet, it doesn't flush without needing a plunger. It does not have a large water tank and doesn't fill alot of water in the toilet either. I don't think it's the wax ring....Could it be just a cheap toilet? Any suggestions welcome.
ernivy3 is offline   Reply With Quote
Old 04-07-2009, 12:05 AM   #2
Plunger in the toilet
The trap inside the toilet must be obstructed of some sort. This indicates that the toilet is cheap. The amount of water in the tank must be too low.
If the tank could be replaced, I would get a new one. Usually, the pipe below the flange is 3 inch or better, so that is not the problem. The other thing to check is the vent pipe: It could have obstruction or it is too far away from the flange. Good Luck.
Gabriel24 is offline   Reply With Quote
Old 04-07-2009, 12:34 AM   #3
I appreciate the suggestion and will try a new tank.
Old 04-07-2009, 08:03 AM   #4
Did you use a "plain" wax ring
or one with a black plastic ring in it?
Old 04-07-2009, 08:23 AM   #5
Rewards Points: 1,548
Some toilet tanks have baffles in them so you can't get the benefit of more water coming down to flush with.
Can you adjust the toilet tank float to let the tank fill higher and does that help?
Not that this will do you any good because toilet tanks sold in the U.S. are limited to something like 1.3 gallons per flush. You could figure out how much water it takes to flush that toilet bowl by measuring off a quantity of water in a bucket at least 2-1/2 gallons in capacity. Conduct tests one at a time after each usage of the toilet.
Old 04-07-2009, 09:57 AM   #6
Unfortunately
, I can't raise the water level because the tank is small. The toilet states that it is a 1.6 gallon per flush, but...
Also, yes, it is uge wax ring with the black reinforced rim on it.
Old 04-07-2009, 11:35 AM   #7
Rewards Points: 150
try putting 2 gallons of water in a bucket and the next time instead of flushing dump the water from the bucket into the bowl and see if it flushes. If it does then the problem might be with the tank if it doesn't flush the problem is somewhere else. Might make sure your wax ring is on correctly sometimes in installation they tend to move and block your pipe. which is why i always put the wax ring on the bowl verses the flange when i install them.
al's sewer is offline   Reply With Quote
Old 04-07-2009, 12:59 PM   #8
I will try all of those suggestions and update tomorrow.
Old 04-13-2009, 11:39 AM   #9
If all else fails get a "Toto" brand toilet.
UFoPilot is offline   Reply With Quote
Old 04-13-2009, 03:28 PM   #10
Safe, Most of the Time!!
brokenknee's Avatar
All manufacturers have their economy line and their quality line of products.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-23-2009, 03:47 AM   #11
Rewards Points: 1,016
Agreed -
This was the solution to my the poorly flushing contractor grade water saving toilets that were installed when the house was built.
I got the one piece (easy to clean), elongaged (comfy), and with the soft close seat/lid (just tab it start it to close and walk away).
Old 04-23-2009, 07:07 AM   #12
Originally Posted by vsheetz View Post
Agreed -
Our Toto Drake will consume a live rabid badger and stare back at us with a "that all you got!?" look.
learned about it at the terry love toilet forum.
ATLdrew is offline   Reply With Quote
Old 04-23-2009, 08:09 AM   #13
RippySkippy's Avatar
Before you go a "drop a a load" on a Toto, remove the throne and look up into the horn....here's my experience...
"Someone" in my house...dropped a deuce that somehow made it through the bowl trap but would not go through the outlet where the wax ring mounts. After fish'n for and catch'n the brown trout, it was HUGE, and HARD...good god it was disgusting. It has since flushed to make the Niagra Falls look like a stream. Now mind you that's no rabid badger...but pretty darn good!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-23-2009, 12:23 PM   #14
Newbie Bill
Rewards Points: 522
OMG guys, I just about had diet coke coming out of my nose from laughing so hard.
Rabid badger, drop a load, dropped a deuce, brown trout. You guys are hilarious.
Ernivy3, please let us know how this turns out.
drtbk4ever is offline   Reply With Quote
Old 04-23-2009, 03:12 PM   #15
Rewards Points: 356
This could simply be a defective product as the poster states "newly installed trovani toilet". Why not return it and try a new one. It only take 30 minutes or so to remove and replace a crapper and a new wax ring is only a couple of bucks.
Rege
RegeSullivan is offline   Reply With Quote
Unused toilet - clogged? co2 plunger? Tommy2 Plumbing 16 12-02-2008 03:06 PM
Noise, hollow, movement on cultured marble floor...need help? handfix2008 General DIY Discussions 8 11-04-2008 08:25 PM
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 12:07 AM
Plunger style drain stopper stuck engineerdixson Plumbing 3 06-09-2008 06:38 AM
Foundation movement question kelly001 Building & Construction 5 10-02-2006 06:09 AM
