Have A Slow Leak,possibly Behind The Wall?? Plz Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2009, 05:44 AM   #1
Exclamation
have a slow leak,possibly behind the wall?? plz help
hello there,ive only just registered so im new to this but really dont where to turn to so i would really appreaicate some advice !
well we had a radiator plumbed in ,,in the hallway and he used copper piping behind the wall,but he couln't get one long peice down from the loft so he used 2 peices and then soldered them together.we've only just notived after a few weeks of him leaving that my underlay is soaked under the carpet.we've dried the underlay out ,put it back down but after been holiday for 2 weeks we;ve come back to find yet again that the underlay is soaked again.called plumber today who then say's hes going to fetch some internal leak selant as it might be coming under the skirting board and to see if he can iliminate it,,but to be honest he's been terrible plumber and his he right? and will it work because he doesn't want to knock the wall out to determin where the leak is..but its got to be his handy work and my bolier keeps dropping pressure beacuase there's a leak in the house.
please can anyone tell me is my plumber right?
need uregent advice
xx
stokie is offline   Reply With Quote
Old 05-11-2009, 05:54 AM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I have no clue what he's talking about when it comes to an "internal leak sealant". The correct way to fix the problem is to open the wall, find the leak, cut out the offending portion of piping and then repipe. He needs to be sure the leak is actually coming from behind the wall and not a fitting on the radiator. Otherwise, you're going to be mighty po'd if you have a hole in your wall when one wasnt necessary.
Broadcasting from Fort Myers Beach, FL...this is JDC over and out. lol....god I love vacation!
JDC is offline   Reply With Quote
Old 05-11-2009, 06:01 AM   #3
thank you so much for getting back so quickly,,its definetly not coming from the radiator valves as we've put the heating on for 1 hr now and theres now sign of dripping...we think its a slow leak thats built up over a few weeks.if it was a valve the carpet would be wet but it isn't its just the underlay all the time.we cant see the leak at al!! so its got to be in the wall a hollow wall petitioned wall in a small hallway.as we've just a a new bathroom refitt
Old 05-11-2009, 06:09 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Well if your boiler's dropping pressure, your underlayment is wet and you just added piping behind a wall, I'd say that's where the trouble is....sorry
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 01:59 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
