#1 |
Have a photo of my waste stack; suggestions concerns?
I have a few questions pertaining to the below photo, mind the dog please….
This is a shot from the kitchen; the far wall is shared with the bathroom on the other side. Its hard to tell from the picture but the drain pipe(copper as is the whole house) for the bathroom sink is on an uphill slope to the waste stack. Besides needing to fix this slope, is this an ok method to drain and vent the bathroom sink? That right now would be the highest part on the stack (no second floor and no vent for the kitchen sink) if that is ok then technically shouldn’t the tub and toilet be on some other vent? Right they they all drain to the waste stack and are below this sink drain. That’s not allowed I can imagine. I do plan on calling a plumber but I like to know this stuff for reference. In this situation, what would be the best options as far as proper venting and draining? Also in the picture is the kitchen drain pipe with goes straight down to an old water trap and then to the main stack. That will need a vent as well. Suggestions as to the best method to drain and vent all fixtures? That is it for the house btw, all right here
#2 |
I can't really tell from the photo: is the knee high horizontal pipe going to the main stack the bathroom sink drain? How far to the left of the photo edge is the sink? Where do the tub and toilet drain into the main stack? Below the floor? Is that a 4" cast iron stack?
There is something called "wet venting" that more or not be allowed in some areas. It has to do with a drain being above a vent in the main stack. I can't really explain when it is allowed other than a small item (sink?) draining above the vent. Let the pros explain a little more. B |
#3 |
sorry i forgot to mention, right at the left cutoff of the photo, that is where the sink drain is for the bathroom. the toilet, kitchen sink, and bathtub all drain into this stack right below the floor. it appears to be 4" maybe 3" i can check when i get home. i live in MA as well. this house is untouched 1959'. they did redo the bathroom but just fixture updates, no plumbing updates. i would say the bathroom sink is 4 or 5' from the stack.
#4 |
call me E
All your fixtures appear to vent at the 4" stack. Per UPC, the only really bad part is the kitchen sink. The bathroom is wet vented and is done pretty much to modern code. (can't see the tub piping) You should at least rebuild the trap arm to the lav. The copper will rot out soon and you have the wall open now so it's a good time to replace it.
S traps as you have at the kitchen are no longer allowed. They tend to siphon themselves dry. Consider a new drain and vent stack in the wall a use a standard p trap.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | ben's plumbing (10-12-2012) |
#5 |
And change those supplys so there behind the walls not through the floors. There no longer code also.
#6 |
thanks for the responses. yes the kitchen sink drain and water pipes will be relocated over to the right about 1.5' and be installed in the wall as you mentioned. are you suggesting to run a secondary vent for the kitchen sink or run it over to the main stack like the sink in the bathroom does?
as for this wet drain method, what exactly does that mean? if i don't hear a response ill take it as i can easily google and learn what it is. i thought i should bring some attention to this point as well. we get a mild sewer gas smell when we use the bathroom sink. any reason for that? how could we fix this? |
#7 | |
call me E
Have a photo of my waste stack; suggestions concerns?Quote:
I could try to explain wet vent but google images will be better- as long as they're showing proper method. Basically, the lower fixture's vent(toilet) is oversized to allow for waste water from upper fixtures. Your lav will not comprimise the vent of the toilet. BTW we're talking vertical wet venting and it has it's limits
#8 |
Super Moderator
That still meets code where I work---it's not wise to place water lines in outside walls in regions that have cold winters.
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | ben's plumbing (10-12-2012) |
#9 |
thanks guys, yes i was curious about in the wall water supplies, i do live in MA which is NE and is a cold climate so i will have to check what the best way to do this is, or im sure a plumber will say the right method. even with the pipes between insulation batts and covered in pipe insulation; its not a good method to put it in the walls of a cold climate?
#10 |
Have a photo of my waste stack; suggestions concerns? |
#11 |
JOATMON
total brain fart.....I thought I was posting a new thread....instead, posted here....appologies to the OP....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by ddawg16; 10-12-2012 at 10:31 PM. |
#12 | |
call me E
#13 |
Super Moderator
Joe lives in a warm area of the country---so he may see them inside the wall more often than not---
| Display Modes | |
| suggestions for repair of 1/2" copper line -see photo | mycophile | Plumbing | 1 | 11-15-2011 06:21 AM |
| flange inside waste pipe but net secured to waste pipe | ctmitch | Plumbing | 2 | 07-12-2011 10:58 PM |
| Basement Waste Stack | The Vintage Sou | Plumbing | 3 | 08-17-2010 02:47 PM |
| Locating Waste Pipe Under Concrete Slab | stubits | Plumbing | 6 | 03-10-2010 10:55 PM |
| Basement Toilet Venting Question | scottgibson | Plumbing | 17 | 02-21-2010 11:34 AM |
