Have Hot Water Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2011, 06:12 PM   #1
Have hot water question
I am putting a addition on my house. Furnace and hot water tank on opposite side that addition is being added on. My house is on a concrete slab. I am thinking of running a cold water line around outside of house and adding a tank-less water heater to service new addition. Which will be 2 bathrooms and a laundry room. Total distance is about 60'. Is this right way to do it.
ckny is offline   Reply With Quote
Old 09-30-2011, 07:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Where do ya live,..?? What's the climate,..??
Bondo is online now   Reply With Quote
Old 09-30-2011, 07:11 PM   #3
New Jersey...
Old 09-30-2011, 07:30 PM   #4
The pipe needs to run through conditioned space or be buried below the frost level for your location.
Bob999 is offline   Reply With Quote
Old 09-30-2011, 07:50 PM   #5
I was going to run 2" PVC underground below frost line like 36 inches. Then run 3/4 or 1" PEX thru that.
Old 09-30-2011, 07:51 PM   #6
Mark Potter's Avatar
Rewards Points: 150
Sounds all good what state do u live? I'm shore it's not going to freeze outside. Lol
Mark Potter is offline   Reply With Quote
Old 09-30-2011, 07:55 PM   #7
Rewards Points: 150
Oh I just got every ones reply's? On this thread Opps disregard my question that was already asked lol
Old 09-30-2011, 07:56 PM   #8
New Jersey. Just wanted to make sure that running a tank-less water heater is the best option and there is not a better way to do it using existing furnace and hot water storage tank.
Old 09-30-2011, 08:05 PM   #9
Rewards Points: 150
If it's new jersey ? I wouldn't r u building addic as well? How big is your cold feed line that your running?
Old 09-30-2011, 08:26 PM   #10
There will be a small attic space. There is no way to get there from existing basement area without destroying a bunch of existing house.
Old 09-30-2011, 08:50 PM   #11
Rewards Points: 150
The best way to do this line is through a small Chase either on top or bottom corner of the new edition.
Old 09-30-2011, 09:00 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 820
PVC? Wouldn't PEX be a better option? Less likely to break just in case it does freeze..
Old 09-30-2011, 09:42 PM   #13
Rewards Points: 150
If it needs to be outside below the frost line run low voltage heating wire with it.
HP Properties Capital Projects
Old 09-30-2011, 10:07 PM   #14
Thanks for the help everyone. I'm sure I will have some more questions as project gets going.
Old 09-30-2011, 10:13 PM   #15
Missouri Bound's Avatar
I would add a tank water heater before a tankless one. Gas is not that bad, but electric are huge energy hogs.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Yet another sump pump / pit question SeanFlynn Plumbing 0 01-24-2010 02:07 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
