Has Anyone Used The Watts Quick Connect Fittings? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2008, 08:26 PM   #1
Has anyone used the Watts Quick Connect Fittings?
Has anyone used the Watts Quick Connect Fittings? I here they can be used with PEX Copper and Cpvc. Are there any tricks? How did you like it? My bro-inlaw used it no probs and loves it. No soldering! thats great. I want to rough in the supply lines for my bar bath and Mud sink.
luweee is offline   Reply With Quote
Old 03-06-2008, 07:30 PM   #2
I just replumbed part of the house with the Watts quick connect fittings. It was extremely easy and no leaks yet. It tied the old copper piping to new Pex with no problems yet. It has been 4 weeks and no leaks. I was visiting the site to find out if anyone had any reliability information on them.
I've read bad things about Qest but can't find anything on Watts.
njmckenzie is offline   Reply With Quote
Old 03-07-2008, 10:56 AM   #3
I would check with the local Code office before using them. In my opinion, they are "still" a compression fitting and most codes do not allow them in areas that are not readily visable. I have used many Watts products and they make quality stuff, but that doesn't make them legal.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-07-2008, 09:09 PM   #4
Knucklez's Avatar
Rewards Points: 930
i don't know about watts in particular, but i have used other compression fit. look on the label for "in wall" application rating, then you know it's ok. also call the manufacturer if it doesn't say.
you need to crank these things good with long 12" pliers. and use nice pink thread tape. i tightened one using good strength and it leaked on pressure test!.. so i broke out my 12" adjustable and gave it everything i had (i'm not the strongest in the world..). then it was OK.
if you tighten it like this it is OK, but you may not be able to get it off in the future without a pipe puller thingy cause the copper ring actually compresses the pipe.
on the other hand, solderd copper is best especially for piece of mind. i used compression because i was scared to solder around the joists and lath.. for fire reasons. then later when i was more used to plumbing i was not scared, but instead just worked carefully with heatshields and spray water bottle and fire extinguisher (near exit).
i'm not expert.. but i think go for it!
Knucklez
Knucklez is offline   Reply With Quote
Old 03-08-2008, 10:15 AM   #5
If you have ever worked with a Code inspector, you know that they can have attitudes if you try show or tell them that something is Code Approved. They have their own books and don't care how many website copies from fitting manufacturers you show them. It's the "wording" that is important. I had an inspector tell me that "code compliant" was not "code accepted". The worst problem comes when you attempt to sell a home and the buyer hires a Home Inspector who questions these fittings. Real pain to need to go back and replace when you have other things to do. This is why I always tell people to check with their local Code office.
Old 03-08-2008, 11:06 AM   #6
Talking
Watts, yup, good
I've used watts and other brands that do the same thing...If you are a novice plumber ALWAYS USE THEM.
I did however make the mistake of trying to just bond regular pvc elbows in (trying to save money). I waited the prescribed time and turned the water on...Not funny, I like fountains n' all but not in my bathroom...Ended up going out and spending the dollars for the quick connects. For the inexperienced plumber they are the absolutely safest and best way to go.
rookiePhilip is offline   Reply With Quote
Old 03-08-2008, 11:10 AM   #7
Side Note
Shark quick connects at HomeDepot are now my 'go-to' plumbing answers.
If you are plumbing the house with the flip/sell intention maybe you should make the pipes inaccessible or hidden. The renovator that did our house screwed the access panel down, calked it shut and then painted over it all...I had to tear into that and replace ALL his 'plumbing'...my kitchen ceiling still isn't right...
Old 03-08-2008, 11:16 AM   #8
6 months with my Sharks from HomeDepot and no problems. Isn't it amazing that they can join the dissimilar pipes...(pex w copper)
Old 02-28-2011, 09:02 PM   #9
watts Quick Connect
I have talked to the engineerss at Watts as I am planing on using them in a large sailboat. They tell me they were developed for use on US Navy vessels as the vibrations at too hard on solid connections. They are up to Code here in Ontario Canada and being used in new home construction. I am going to use them. Remember on a boat if they leak you sink in a house you only get wet.
sord is offline   Reply With Quote
Quick connect sink? rick32 Plumbing 2 12-13-2007 02:07 PM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 08:59 PM
ice maker line in wall and fittings cshousley Plumbing 5 10-01-2007 05:01 PM
Watts vs. Volt-Amp Billing? Max P Electrical 19 07-24-2007 08:05 AM
Watts to Amp Rze Electrical 2 08-10-2006 01:57 PM
