Has Anyone Used Root-x On Their Sewer Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2011, 08:40 PM   #1
has anyone used root-x on their sewer pipe?
If so, please share your experiences, both good/bad.
We had a problem with roots growing into the sewer pipe (PVC). I am collecting as much info as possible from others.
Also, can roots damage a PVC pipe?
Thanks and have a great day!
corsica is offline   Reply With Quote
Old 10-31-2011, 10:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 568
I don't recommend any chemicals down the drain. The reason is that I have no evidence any of the products work. I can safely say though, none of these products are as good as a water tight sewer line. IMO, your better off using a jetter periodically to cut out the roots until you replace the pipe. And yes, roots will damage any pipe.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
