Old 01-29-2007, 08:56 PM   #1
jrm
Default Harden faucet stem removal
I have an old harden three valve shower set-up. I'm trying to remove the deverter valve but it's stuck.What I'm trying to do is find a puller that fits this valve, I guess? I jerry rigged a puller on another valve because the stem unsrewed but this one is not budging. Holding on to a stem is a mystery to me. Help!
jrm is offline   Reply With Quote
Old 01-30-2007, 08:57 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
A picture would be helpful.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-30-2007, 07:48 PM   #3
jrm
I think if I could add a picture it would be easier than fixing the faucet. I took the picture but have no idea how to add it to this thread. My picture is too large to send and I can't figure out how to get it smaller without losing quality, Oh well.
Old 01-31-2007, 01:28 AM   #4
Open it with MS paint go to Image: Strech/Strew and put the percentage you want to shrink the image in each box. For example if you wanted to make it half the size type 50 in both boxes.
Then go to www.imageshack.us
Uploading the picture is self-explanitory
Once it's uploaded get the direct image adress (all the way at the bottom)
Then come here and type [IM*G]you're image adress here[/IM*G] but omit the asterics.
Tmb9862 is offline   Reply With Quote
Old 01-31-2007, 03:22 PM   #5
jrm
Close -up picture of deverter valve that is stuck
Old 01-31-2007, 07:00 PM   #6
Journeyman Plumber
If you chip away the motor from around that stem, you might see the back side showing the hex that unscrews this, I don't know this brand just taking a guess at this.
Old 02-01-2007, 02:55 PM   #7
jrm
I've added new pictures to show you that I've allready removed the Hex nut. All that is left to do is to remove the cartridge, which is the problem, it won't budge.
harden-faucet-stem-removal-harden-faucet-stem-001.jpg   harden-faucet-stem-removal-harden-faucet-stem-003.jpg   harden-faucet-stem-removal-harden-faucet-stem-002.jpg
Old 02-01-2007, 03:55 PM   #8
Spray it with penetrating oil or WD-40 and allow it to sit for a short while.
redline is offline   Reply With Quote
Old 02-01-2007, 04:17 PM   #9
Journeyman Plumber
It should just unscrew from there then, counter clockwise. This is all guessing, like I say, this is not a valve seen around here.
Old 02-01-2007, 04:42 PM   #10
jrm
It acually pulles straight out, I've done this before. Holding onto it and pulling is the problem. This cartridge has O rings so getting it lubed is a problem but what I think I'm going to do is place the oil in the shower head pipe, maybe this will penitrate.
Old 02-01-2007, 04:44 PM   #11
Journeyman Plumber
Attach the handle back on it, use handle for pulling leverage.
Old 02-01-2007, 04:50 PM   #12
jrm
I think your right but I need to jerry rig a puller at the same time. There's to much force needed to pull with your hands and it needs to be an even presure.
More On This Topic
There are many websites out there that let you upload and share your photos with friends and family members; Photobucket is one of the most popular ones online today. The process of uploading your photos is fairly straight forward, but you may be... Read More »
So now we'll place this in the frame and double check it and make sure that it fits well. And it doesn't. So, I'm going to have to make another cut. I take it the frames out of square. That's one problem you have with wooden frames. Not everything is... Read More »
Reversible Picture Supplies
Reversible Picture Supplies by Expert Village
Today I am going to show you how to make a reversible picture. What a reversible picture is is that it is a two-sided picture. There are two individual pictures. And there is going to be folds running down the paper from top to bottom. Depending on which... Read More »
The first thing we want to do is start by drawing our picture; one of the pictures that's going to be used for the reversible picture project. Now, it's important to note that when you're drawing your picture, it should take up the entire space of the... Read More »
Hi, I'm Gary for Expert Village. You see our pictures are pretty much the same size. I just want to make one more edit and take off some of the edges on this pictures because it's a little bit wider than the second picture. And when the frames, the... Read More »
Harden Faucet Handles jrm Plumbing 2 07-19-2008 12:16 AM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 08:08 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 06:56 PM
Cracked cement stem wall in garage pen2paper Building & Construction 0 11-28-2006 03:29 AM
garage door removal fishinAK Building & Construction 5 07-06-2006 11:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
