Old 02-03-2007, 08:50 PM   #1
jrm
Harden Faucet Handles
Does anybody know where I can find Harden handles. These are about 20 years old that are pictured. I'm looking for a similar look but all chrome including handle, the exsiting is ceramic. I'd probably look at anything that is compatible with the harden splin setup. I need at least eight.
jrm is offline   Reply With Quote
Old 02-05-2007, 12:25 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Here is one place online that sells splines and handles separately.
http://www.plumbingsupply.com/handles.html
Plumbing supply will likely be MUCH cheaper for the splines. Bring one of your valve stems to match up. They will have a thingy that you can try your valve in to see which spline you need. Then you pick your handles, buy your splines and you are all set.
Brik is offline   Reply With Quote
Old 07-18-2008, 11:16 PM   #3
I've been looking for replacement handles like the one you've pictured. Do you still have those handles? Did you find replacements?
-WR
wfredmr is offline   Reply With Quote
Harden faucet stem removal jrm Plumbing 18 03-19-2011 05:47 PM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 07:08 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 05:56 PM
Faucet replacement rondo Plumbing 2 12-03-2006 01:49 PM
spinning sink faucet doddsm Plumbing 1 07-11-2005 11:28 PM
