Hard Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2007, 12:31 PM   #1
chicagoRandy
chicagoRandy's Avatar
hard water
How do you determine if you have hard water and need to install a whole hoiuse filter/softener?
chicagoRandy is offline   Reply With Quote
Old 12-10-2007, 12:33 PM   #2
chicagoRandy
AquaPex Pipe
Anyone have any experience with Wirsbo AquaPex Pipe for potable water plumbing?
Old 12-10-2007, 07:20 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Does your water Stink,..??...
Does your water leave Rust stains on the fixtures,..??...
Does your water Rot the plumbing fixtures,..??.....
Does your water leave Stains on the dishes,..??... Toliet bowl,..??..
Does you water Taste Bad,..??....
If Yes,...... You might want a Softener.........
What I've done with Pex,...... I like it........
Old 12-12-2007, 12:02 PM   #4
Hard Water help
I heard about the bans on water softeners and also found out that sodium and filters can cost a fortune each time you need more. I did a little research and found a small company that sells a water conditioner that needs no maintenance or installation and NO FILTERS AND NO SODIUM. I paid a one time price and i'm stoked. The conditioner is called VWP and is made by Nilemark(swedish). You can e-mail the guy i bought it from at: sso@vwp-usa.com
They give you a money back trial but i didn need it. You feel and taste a difference in days. AND ITS GOOD FOR THE ENVIRONMENT!!!
frizzak is offline   Reply With Quote
Hard water - 37 gpg, .088 iron content. What softener will work? fillys6 Plumbing 9 04-27-2007 09:55 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
hard water Justin1635 Plumbing 2 12-26-2006 07:13 PM
Hard Water or Water Heater Sediment ? sdcards Plumbing 6 08-20-2006 06:37 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
