Hard To Reach Leaking Gate Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 08:29 PM   #1
Lord of Slums
Rewards Points: 1,974
Hard to reach leaking gate valve
I have a leaking main valve that has been built around. I can touch the handle and turn it while on my toes. I tightened the packing nut and it appears to have stopped leaking. Has anyone ever seen a closed nut that I could use to by pass the gate valve. That is, remove the insides of the gate valve and seal the outside while letting water go through. I realize there are many different kinds of valves so I am going to have to figure a way to cut the valve out. It is in an office building, and trust me, real nightmare trying to access this valve. I will try and braze the packing nut to the stem first. There is a shut off at the meter.
mj12 is offline   Reply With Quote
Old 03-16-2013, 08:35 PM   #2
Rewards Points: 214
got a picture? would help us see what your seeing. If you could post one, would be helpful.
jmon is online now   Reply With Quote
Old 03-16-2013, 08:51 PM   #3
Rewards Points: 13,256
DO NOT BRAZE THE NUT!
If it's not leaking any more why mess with it.
Any time a gate valve opens or closes it's common of them to leak a little around the shaft. A little tweek on the nut and it gone.
The nut can just be repacked if it keeps leaking.
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 08:52 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 02:01 PM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 08:11 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
