Hanging A Shower Curtain Rod On Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2010, 09:03 PM   #1
Rewards Points: 682
hanging a shower curtain rod on tile
I have a shower where the tiles go to the ceiling. I am thinking about drilling tiles with a masonry drill, installing those plastic screwholders they use for drywall, so I can keep a shower curtain rod in place.
Is this a good idea? I'm a little worried I will crack some tiles in the process.
darsunt is offline   Reply With Quote
Old 06-21-2010, 09:13 PM   #2
Just call me Andrew
Rewards Points: 1,020
Why not just use a rod that doesn't screw in anywhere - they are like tension rods that unscrew and get wider, wedging themselves in place.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
drtbk4ever (06-22-2010)
Old 06-21-2010, 09:18 PM   #3
Rewards Points: 682
I would like to. But my experience with tension rods so far is they tend to bend and bow instead of tightening up against the wall. Then they slip.
Did you find a tension rod that works well?
Old 06-21-2010, 09:20 PM   #4
Just call me Andrew
The one i have used in my house has worked just fine...
If you do decide to drill into tile, get a tile-cutting drill bit.
Andrew
Old 06-21-2010, 09:22 PM   #5
Learning by Doing
Leah Frances's Avatar
Bought a cheap one at Target. It's been up for 3 years now with no problem.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-22-2010, 06:25 AM   #6
Handyman
Rewards Points: 512
buy yourself a diamond tile drill bit. Much faster than a masonary bit and less chance of cracking the tile. Cost is about $6 at HD
canadaclub is offline   Reply With Quote
Old 06-22-2010, 07:05 AM   #7
Rewards Points: 156
I agree with Canada, use a diamond tipped drill bit. I did this and it worked out fine. Drill slow and let the bit cut into the tile, apply pressure, but don't be pushing as hard as you can. Also, use a cup of water to dip the bit into every so often to keep it cool, you can also wet down the area you are drilling into. Good luck.
Branden is offline   Reply With Quote
Old 06-22-2010, 07:15 AM   #8
Handyman
Rewards Points: 512
Yep, good point
replacing my current prefab shower unit with tile...Can I use the existing pan and just tile above it? Austin Kitchen & Bath Remodeling 1 05-20-2010 10:02 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile shower pan leaking Daniel048225 Building & Construction 2 10-15-2009 02:18 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
