Handle On Toilet MUST Be Held Down Throughout Flush - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2013, 07:11 AM   #16
Originally Posted by Willie T View Post
Yeah, except that this one really works... and well. The weight of the water in the attached cup keeps the flapper wide open till after every last drop of water has left the tank. By that time, water dribbling out of a tiny hole in the bottom of the cup allows the cup to finally empty, thus removing the offsetting weight, and the flapper snaps shut.
Really pretty ingenious. And super simple... no moving parts except the regular flapper hinge.
Found your reply in some old posts, but the picture of your solution won't come up. I would really like to see your solution. Is there some way you can send the picture to danellis1701@verizon.net?
dadala is offline   Reply With Quote
Old 11-04-2013, 09:27 PM   #17
Fluidmaster 555c Flusher Fixer Kit (google it) I believe is what you are looking for ^^ based on the expired URL that was posted.
fix3r21 is offline   Reply With Quote
Old 10-27-2014, 10:19 PM   #18
Rewards Points: 2
Originally Posted by Mike Swearingen View Post
Install a regular non-water saver flapper with the little rubber "ears" hooked onto the L-shaped brackets at the bottom of the overflow pipe in the middle of the tank instead of with the round rubber ring on the flapper (cut that out with scissors)...works better that way.
Shorten the cahin to where it just allows the flapper to close completely.
Should solve the problem.
Good luck!
Mike
Amazing. Built a half-bath out of a section of a room we weren't using...ran new plumbing, installed everything myself. Everyone in house has been complaining about having to hold the flush lever on the toilet to complete a flush...this fixed it.
Snip snip. Thanks!
rswearing is offline   Reply With Quote
Old 10-28-2014, 05:49 PM   #19
Rewards Points: 2,104
Might try shortening the connection from that handle to the flapper. Your flush action may not be lifting the flapper up fully.
Old 12-24-2014, 04:08 PM   #20
Rewards Points: 2
Thumbs up
Good luck!
Mike
7 years later and your advice is still saving time. Thanks for saving me a trip to the hardware store for a new flapper. I would have never thought that would cause such a problem.
TXOgre is offline   Reply With Quote
Old 12-24-2014, 04:35 PM   #21
Rewards Points: 582
my guess its a korkey flapper with the rubber ring that slides over the over flow tube....need picture to comfirm but if that is it...will need to cut ring to install on ears of the flush valve and yes adjust chain...
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 10:29 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
Raised toilet flush problems ricgail Plumbing 2 11-17-2006 06:06 PM
Flush toilet, hear shower drain noise joedadog Plumbing 1 04-01-2006 12:52 AM
