Handheld Electric Pipe Threaders - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2007, 10:49 PM   #1
Custom Knifemaker
Question
Handheld electric pipe threaders
Has anyone here used one of these? I am thinking of buying one, but there are no stores nearby that I can examine one before I buy. To me it looks like the tool rotates the threading die and the pipe has to be held fixed by some other means (ie. vice). Is this correct?
Thanks in advance,
Firebug
Firebug is offline   Reply With Quote
Old 11-23-2007, 09:11 AM   #2
Send a message via AIM to Marlin
That is correct. The pipe is held typically by a chain vice or a top screw vice. I prefer the chain vice.
You could hold the pipe back using a pipe wrench you have fixed in place somehow. Be carefully with this though because those threaders have a ton of torque and if that wrench comes loose it can cause some real damage. Pipe threaders are not toys, be very careful with them. They have a ton of torque and can easially snap your leg or rip fingers or arms right off if you get caught right way, and it's possible to get jammed in such a way you can't let go of the trigger. I don't mean to scare you, just know a pipe threader is no less dangerous then a power saw.
This is the threader I use. It's a great tool but is on the expensive side. It's about $1,000 new. I paid $600 off eBay for an almost new one with a chain vice, dies, cutter, and a few ratchet cutters.
Don't forget you need some kind of oiler too even if it's just a coffee cut and a bucket.
Marlin is offline   Reply With Quote
Old 11-23-2007, 09:49 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Be sure to hold on when you use the electric threader.
It can catch you off guard and hurt you.
jbfan is online now   Reply With Quote
Old 11-23-2007, 10:47 AM   #4
Custom Knifemaker
Thanks Guys,
Thats what I was hoping, and I know what you mean about power tools with torque. My Twisting machine has over 650 ft/lbs of torque and when it is going its hands off, the thing could rip your arm right off.
Thanks,
Firebug
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
