Hammer Arrestor Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2012, 10:53 AM   #1
Where would you put water hammer arrestors in this situation: 1 2 or 3? If 2 or 3, I would use a 90 to ensure the arrestor is vertical.
The Bosch is vibrating when turning on the hot water heater; it, too often, errors out causing me to reset the heater. After researching this, it seems to be common with this water heater model and arrestors may help. I installed one on the cold side in-line but it didn't last; I'm thinking these need to be placed at corners or ends.
brainstewn is offline   Reply With Quote
Tags
arrestor , tankless , water hammer , water heater
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
