Hammer Arrestor Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2012, 10:41 AM   #1
Where would you put water hammer arrestors in this situation: 1 2 or 3? If 2 or 3 I would use a 90 to ensure the arrestor is vertical.
The Bosch is vibrating when turning on the hot water heater. After researching this, it seems to be common with this water heater model.
brainstewn is offline   Reply With Quote
Old 06-15-2012, 11:44 AM   #2
Rewards Points: 16
Probably better off posting in the Plumbing section, as I don't think you're supposed to ask questions in the How To Guides section.
siggyfreud is offline   Reply With Quote
The Following User Says Thank You to siggyfreud For This Useful Post:
brainstewn (06-15-2012)
Tags
arrestor , tankless , water hammer , water heater
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 10:17 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
