Half Inch Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2011, 02:51 PM   #1
half Inch gas pipe
Has anyone had a problem with very small seapage of gas through half inch gas pipe joints. If so is there anything to seal the joints. It is not possible to take the joints apart to reseal.
Jim Skyblue is offline   Reply With Quote
Old 01-04-2011, 03:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... ANY seepage from a Gas line needs fixin',... Now, not later...
Whether that includes totally redoing it, just just tightening what's loose...
Old 01-04-2011, 04:06 PM   #3
Licensed Master Plumber
Without taking the joints apart there is NOTHING that will seal them. Don't even think about Mighty Putty or any of that other crap.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
The Following User Says Thank You to NHMaster For This Useful Post:
plumber666 (01-05-2011)
Old 01-04-2011, 10:33 PM   #4
Picky Plumber
I see alot of gas leaks, especially at the equiptment. The gas needs to be turned of to make the repair. Gasoila, RectorSeal, any pipe thread sealant that states "use for gas" will work. Just please, know what you are doing and if you are the least bit unsure, call your plumber or utility company and have them do it for you. You don't often get a second chance to fix a problem like that.
Plumber26 is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Can I unglue PVC 1 1/2 inch pipe? ex-Khobar Andy Plumbing 12 11-06-2009 03:17 PM
running black gas pipe lukeg Plumbing 6 10-25-2009 12:16 AM
Pipe fell down well-- Help me get it out? rjniles Plumbing 27 08-09-2008 02:39 PM
