Half Bath To Vent Or Not To Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 05:30 PM   #1
Rewards Points: 143
Question
Half Bath to Vent or Not to Vent
Hi everyone, I have a split level house that has a half bathroom in the basement near the front door. The bathroom has a window. I was thinking of adding a fan since we are remodeling it. But if I did add it, the only place to vent it would be to the front of the house right by the main door via the cantilevered joists. Then I would have one of those dryer vent doors and possible stinky smell about 2 feet from the main door.
Above it is a full bath, unless I could somehow run some 2" inch pvc up the framing wall and then patch into the vents exhaust from the bathroom above.
Not sure if that is doable or makes sense.
Thoughts?
cloves is offline   Reply With Quote
Old 05-20-2013, 07:12 PM   #2
Rewards Points: 636
where i live no exhaust vent is needed if you have a active window. but i always try to add an exhaust vent when i can in your case i would put a soffit vent style in the bottom of the cantilevered part. and as far as smell if it smells that bad it is better it is outside not inside peeling the paint of your walls.
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-20-2013, 10:11 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm confused. You're talking about an exhaust vent in conjunction with 2" pvc? The two are not compatible. Are you talking about an exhaust vent or a sewer vent?
Journeyman Plumber
Old 05-21-2013, 12:37 AM   #4
I've never seen a sewer vent with a dryer vent block, so I'm guessing a frat fan.
But I'm very interested in this 2" PVC for the vent. How are you planning on doing that?
jsbuilders is offline   Reply With Quote
does sealing gap under bathroom door impede operation of bath vent fan? daluu HVAC 6 05-02-2013 01:12 PM
Half Bath Conversion kingbuggy Plumbing 5 05-03-2012 09:13 AM
Valid vent for basement bath? bdowden Plumbing 4 09-30-2011 03:43 PM
location of ac vent in bath mazey HVAC 3 09-08-2011 08:03 PM
Will this bath vent routing work? Homerepairguy Kitchen & Bath Remodeling 5 01-05-2011 06:05 PM
