Hair In Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2007, 10:37 PM   #1
Hair in tub drain
Hi everyone, does anyone know how to get the hair out of the tub drain. I cannot get my hand down the hole to pull out the hair it is all wrapped around the little drain thing about 2 inches down. thanks kenney
danceken is offline   Reply With Quote
Old 04-20-2007, 10:41 PM   #2
Rewards Points: 1,088
Metal clotheshanger?
handy man88 is offline   Reply With Quote
Old 04-21-2007, 07:57 PM   #3
Home Improvement Guy
ron schenker's Avatar
Needlenose pliers?
Slice the hairs with a utility knife then flush them down?
ron schenker is offline   Reply With Quote
Old 04-22-2007, 05:11 PM   #4
Rewards Points: 150
Wink
I've used the needle-nosed pliers. Just put a couple of paper towels in the bath tub to put the collection on.
Then I suggest pouring some baking soda in the drain followed by a cup or two of vinegar to clean the drain out and freshen it up.
shapeshifter is offline   Reply With Quote
Old 04-23-2007, 09:50 AM   #5
not a total Newbie
I used a coat hanger with a little hook bent on the end. Apparently, the previous owner had some long hair and a shedding problem.
space_coyote is offline   Reply With Quote
Old 05-24-2007, 09:53 PM   #6
Remove overflow plate
If it's an older style tub like mine, you can remove the two screws from the overflow plate. Attached to the plate is the lever to switch from tub to shower. Gently pull the plate away from the tub and pull up on the rod that is attached to the plate and lever. The rod goes down to the drain and has a curly springlike piece attached to it. That curly piece is what collects the hair. Clean it and put it back in the same way it came out. This should be done at least twice a year, depending on how many people are in your family.
Good Luck
Dziadzij
Dziadzij is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
