Had This Problem Before - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2011, 04:32 PM   #1
Had this problem before
Hi, I just replaced a leaky Moen shower stem. This is probably about the 3rd one in 15 years. I'm getting hot water only when turned to the right or left and low pressure in the middle. I tried rotating the stem 180*, no change.
Last time this happened I ran the water with no stem installed to possibly clear any obstructions, and that worked. Well I tried that again but still no change. What am I doing wrong?
uconduit is offline   Reply With Quote
Old 09-18-2011, 02:16 AM   #2
Is there a knowledgeable plumber in the house???
Old 09-18-2011, 05:17 AM   #3
DIY staff
Rewards Points: 7,174
Have you cleaned the inside of the valve body with a bit of sandpaper?
Sometimes a piece of the old rubber gets jammed into one of the ports--a length of copper wire some times helps.
It's also a possibility that some crud is lodged in your new cartridge.---Mike---
plumber666 (09-18-2011)
Old 09-18-2011, 01:44 PM   #4
Thanks Mike, I'll try that.
Old 09-18-2011, 02:45 PM   #5
No luck, any more suggestions?
Old 09-18-2011, 06:48 PM   #6
DIY staff
Have you flushed it again?
Old 09-18-2011, 11:48 PM   #7
Yes, I flushed it again. No change. One thing I did notice is, of the last two cartridges removed, there is a small chunk of rubber missing in almost the exact same spot.
Old 09-19-2011, 10:18 AM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How often is the valve used?
If they're not used daily they tend to dry out a little, and the balancing spool inside gets stuck. A little plumbing grease goes a long ways.
Journeyman Plumber
Old 09-19-2011, 07:11 PM   #9
At least twice daily. Plus, it's a brand new cartridge. What I don't get, is that this happened last time I replaced one so we called someone out and as far as I know, they only flushed it and that one lasted a few years. I have been told that my pressure is too high.
Old 09-19-2011, 10:35 PM   #10
Doing it myself
Alan's Avatar
Interesting. By the lack of cold water entering the valve though, it still sounds like a stuck balancing spool.
Is it a MOENTROL rough in valve or a POSI TEMP rough in valve?
They are very different monsters.
Journeyman Plumber
Old 09-20-2011, 09:32 PM   #11
Couldn't tell you which type it is. All I know is that this place was built in '74.
Old 09-20-2011, 09:36 PM   #12
If I flush it again, what temp should the water be? Both hot and cold? I haven't been messing w/ it lately because the water temp is actually the way I like it! The lower pressure doesn't really bother me too much. My wife on the other hand uses the other shower!
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
