Had An Idea For A Safety Device - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2010, 08:29 PM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Originally Posted by Mike in Arkansas View Post
Maybe I dreamed this or maybe it's due to senility but I swear I saw the plumber guy on Ask This Old House install a mechanical devise that shut off the water in case of a broken pipe. I believe it sensed the pressure drop across itself and and turned off the water if the drop got too high because too much water was flowing.
Maybe there is such thing, but wonder how it differentiates a broken pipe, or someone filling the bathtub. Guess it's time based too, like if it's been going for an like half an hour then something is wrong.
Old 06-13-2010, 03:14 PM   #17
http://www.watts.com/floodsafe/
acerunner is offline   Reply With Quote
Old 06-13-2010, 05:05 PM   #18
Ideally you'd have a neural network that learns your weekly water usage patterns and trips on anomalies. For guests and special events you could have a manual override.
False trips are probably not harmful unless you have something that is 'harmed by the absence of water' so this could be programmed with a slight bias in the 'safe, not sorry' direction.
Old 06-13-2010, 05:11 PM   #19
Wire Chewer
Rewards Points: 90
Hmm yeah that makes sense. Most appliances such as dishwashers will detect lack of water and stop operating right? A washing machine for example will wait till the water reaches a certain level before moving on to the next cycle, so worse case scenario it just stops until the water is back.
Old 06-13-2010, 05:26 PM   #20
If you can write good BS in a proposal, someone will come up with venture capital for this project and then I can start hiring illegals to assemble these things.
Are these good respirators and safety masks? darsunt Tools 3 02-24-2013 07:34 PM
Seal for a leaking hot water heater safety valve topspinken General DIY Discussions 9 10-14-2009 03:51 PM
health and safety agula_jonson Safety 1 07-14-2007 09:43 AM
Safety rail for loft Pam Remodeling 5 02-26-2007 01:55 PM
Construction safety nightmare 'Andyman Off Topic 2 09-13-2005 11:20 AM
