H2ow-to Water Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2009, 12:40 PM   #1
h2ow-to water pump
I use this to pull water from my well to wash cars and water my yard, etc. Has worked flawlessly for 10 years.....This winter I unplugged my pump thinking I wouldn't use it over the winter. This is the first time I've unplugged it. I was all excited about washing my car (great weather) today so I plugged it back in and now it runs like always but my water pressure gauge doesn't move at all, hence no water. Is there something I need to do to get the pressure back (short of buying a new pump) . I notice that there is a air valve on top of the pump...do I need to pump some air into it.....Any advice will be greatly appreciated.
hunterleej is offline   Reply With Quote
Old 04-04-2009, 06:06 PM   #2
Water quality'n pump guy
It may not be the pump. Can the pump/plumbing have frozen?
Has the pump lost prime, have you checked or primed it?
Gary Slusser is offline   Reply With Quote
Old 04-05-2009, 05:23 AM   #3
h2ow-to
Has definitely not frozen......How do I prime it?
Old 04-06-2009, 10:05 AM   #4
BIGRED
Rewards Points: 252
Hunterleej
I would listen to Mr. Slusser carefully at this point. Unless you actually disconnected the pipes and drained the pump before the weather froze your shallow well pump could very well have frozen and split the housing in one or more places seen or not seen. It would not actually lose its prime until the weather warmed to above freezing. The pump motor will run just fine with the proper power applied, but with no suction on the well the end result is no H2O.
Grampa Bud is offline   Reply With Quote
Old 04-06-2009, 08:39 PM   #5
biggles's Avatar
with it off...pour some water down the first connection on the well pump that you usually put the garden hose on.you need to fill the impellar area to create suction then bump the pump on...to prime it with well water
Water Powered Sump Pump acuteot Plumbing 7 11-23-2008 09:40 PM
new owner---old jet water pump rise n' shine Plumbing 12 09-27-2008 01:39 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Why no water hours after friend pulled our pump? sheriffherself Plumbing 4 11-19-2006 07:10 AM
