Old 03-02-2008, 08:37 PM   #1
H2O htr
I have a gas hot water heater with a circulating hot water system, and the pressure temp. pop off keeps leaking water after the unit runs for a while. It has an expansion tank on it, any ideas on how to fix problem?
tnthvac is offline   Reply With Quote
Old 03-03-2008, 12:32 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
H2O htr
T&P relief valves can go "bad".
Replace the existing one, and see if that doesn't solve the problem.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-03-2008, 08:39 AM   #3
H2O htr
Good Luck!
Mike
It has been doing this since new, I have installed a pressure gauge on the spicket on the water heater and it varies from 55 psi water running and 120 psi after it sets for a while. What is the pressure relief set at on the valve, and could I have a bad pressure regulator on the main line? Thanks for your help!
Old 03-03-2008, 10:07 AM   #4
Professional Handyman
H2O htr
You might want to check the pressure of the cold water coming into the heater since it's probably very close to the main feed in your home. Here in AZ for example, outside pressure regulators are installed in many locations because of higher-than-normal or "boosted" line pressures so that homes in new developments that are farther away can also have water service. I carry a rather simple pressure tester that screws onto a garden hose bib, normally the one closest to the home's water main shutoff. Surprisingly, some of the line pressures on unregulated homes are often way up there, depending upon the time of the day and the water use. In the more serious occurences where no pressure regulator is installed or where it's become defective over time, copper tubes have split, PVC irrigation tubes have burst, toilet supply lines have ruptured, etc. Just a thought here before you get involved with the serious diagnostics.
End Grain is offline   Reply With Quote
Old 03-03-2008, 12:58 PM   #5
I blame ProWallGuy
H2O htr
The T&P ( the one that keeps opening) is normally set for 150 psi and 180 degrees F.
It sounds as though you have one of two problems. The expansion tank is bad, or undersized or... the pressure regulator (the one on the main, incoming line) is failing.
On the expansion tank, you'll find an air fitting, like on a bicycle tire. Let a touch of air out. Did you get water out?
If so, you have a bad expansion tank.
When hot water is heated, it wants to take up more room. The expansion tank is two tanks in one, separated by a flexible bladder. Air on one side, water on the other. The air will compress and give the expanding water someplace to go other than out the T&P. If that bladder has failed, then the tank is completely filled with water and the system has no room to expand, so it opens the T&P valve to 'relieve' itself.
Hope this helps.
Double A is offline   Reply With Quote
Old 03-03-2008, 08:08 PM   #6
H2O htr
Thanks for the help I will try the pressure gauge on the cold water side and I will check the bladder tank and regulator, Thanks for the info!
Old 03-03-2008, 08:23 PM   #7
Journeyman Plumber
Ron The Plumber's Avatar
H2O htr
Originally Posted by Double A View Post
The T&P ( 180 degrees F.
Thats 210 not 180
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-04-2008, 01:31 AM   #8
I blame ProWallGuy
H2O htr
I stand rejected... erm, corrected.
