H/W Cylinder Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2005, 07:05 AM   #1
Unhappy
H/W Cylinder leak
My hot water cyliner seems to be leaking albeit a small drip but never the less a leak.
I can`t see any obvious source but it apperas to be from underneath and running to form a drip at the lip of the base of the cylinder.
Is there such a thing as a radweld (auto repair thingy) type fix it for what must be a very slight hole or is it a new cylinder job.
If a new cylinder job, then is this a big job in itself or quite straight forward?????
Regards
Martin
PS. All plumbing advice appreciated, water is not my strong point
weaverght is offline   Reply With Quote
Old 04-06-2005, 09:39 AM   #2
Is it a copper or galvanised cylinder? Sometimes one of the unions can leak and the water will appear elsewhere. If it were the cylinder leaking there is no alternative but to replace the cylinder, if water is not your strong point I would not try it yourself. If you are in the U.K cylinder replacement comes under building control.
dirkgently is offline   Reply With Quote
Old 04-06-2005, 09:44 AM   #3
Cheers for the reply. It is an old copper tank for reference, I take it the unions are where the copper joins as it doesn`t appear to be one complete tank....
Old 04-11-2005, 04:01 AM   #4
Sorry I forget that it may seem like I’m talking in code. The unions are where the pipes connect to the cylinder
