Gurgling Toilet - Septic System - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 02:23 AM   #1
Gurgling toilet - septic system
I'm new at this so if its already asked sorry to waste anyones time but:
I flushed a toilet tonight and one in another part of the house started gurgling. I've never had that happen before. We are on a septic system so I'm really hoping that it isn't a septic system problem. We've just redone the roof including replacing all the vents. I've also noticed an occasional 'sewage' smell coming from my kitchen sink. I'm hoping it's just a vent, not a septic issue. Any help would be so much appreciated.
wenwil is offline   Reply With Quote
Old 11-18-2011, 07:16 AM   #2
Sounds like you have a partially blocked vent. The system has to get air for the water to flow, if the vent is clogged, it will pull it from toilets, sinks, etc. This causes toilets to gurgle, and sink traps to be sucked dry, allowing sewer gas to escape.
Old 11-18-2011, 07:16 AM   #3
Rewards Points: 1,418
Most likely it is a vent problem.
When was the septic tank pumped last? HOw often you should pump out the tank is and educated guess based on family size and how often it was pumped ou in the past.
A pumping company rep should be able to tell you about problems in your septic system/
Tags
plumbing , septic odors , septic systems
AAV in a DWV system with a septic tank gaaah Plumbing 10 09-20-2011 12:53 PM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 08:41 AM
Gurgling pipes and no system pressure mark4 HVAC 4 12-31-2010 02:03 PM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 07:05 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
