Gurgling Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2012, 05:44 PM   #1
Gurgling Toilet
Hi All,
We've just finished an extension that has included an ensuite. For a couple of months I've had the toilet and shower installed with everything working fine. Yesterday I installed the vanity and two basins to the ensuite and now the shower and toilet are gurgling if the basin or toilet is used (haven't been game to use shower yet). Funnily enough the rest of the house is working fine. The extension piping was completed by a licenced plumber and it connects back into existing piping. House is single storey. I guess there is an air lock between new extension and existing pipework but not sure what to do. any help would be appreciated.
arty_oh_arty is offline   Reply With Quote
Old 09-22-2012, 07:09 PM   #2
Rewards Points: 13,450
Run some water in all the drains so the traps can fill up with water.
Old 09-22-2012, 09:20 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 556
Since a plumber did your rough in- call him back. The cure may be obvious and simple to him
Old 09-22-2012, 09:45 PM   #4
ffemt121's Avatar
Sounds like a venting (or lack there of) problem to me. I would call the plumber back, when he roughed in the bathroom, he should've added a vent stack for that set of fixtures, unless they are within the proper distance from the other stack
ffemt121 is offline   Reply With Quote
Tags
air lock , extension , gurgling
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 08:35 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
