Old 10-09-2012, 01:24 PM   #1
Gurgling sounds after flushing toilet
I had tile replaced in my bathroom. Toilet had to be removed then put back. Now when I flush I hear a gurgling sound after the tank water refills. Did not happen prior to the remodel. Could replacing the toilet cause this problem? What an be done to correct this?
Forestland is offline   Reply With Quote
Old 10-09-2012, 05:45 PM   #2
possibly some sediment got broke loose when the valve was closed to remove the toilet and is stuck in the ballcock. worst case you would replace the ballcock. i would try taking the ballcock apart and flushing it out first if it's new enough. if its been in there a while i would just replace it.
Old 10-09-2012, 06:47 PM   #3
Thanks so much. I'll try this.
Old 10-10-2012, 03:42 PM   #4
This worked Thanks again for your help.
Forestland
Toilet Flushing Issues Chrishwa Plumbing 3 08-04-2012 01:13 AM
Toilet UNDER Flushing...?? andsoitgoes Plumbing 20 07-26-2009 01:23 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet flushing problem jules81 Plumbing 4 06-02-2008 02:06 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
