-   -   Gurgling sounds after flushing toilet (http://www.diychatroom.com/f7/gurgling-sounds-after-flushing-toilet-159534/)
Forestland 10-09-2012 12:24 PM
I had tile replaced in my bathroom. Toilet had to be removed then put back. Now when I flush I hear a gurgling sound after the tank water refills. Did not happen prior to the remodel. Could replacing the toilet cause this problem? What an be done to correct this?
DannyT 10-09-2012 04:45 PM
possibly some sediment got broke loose when the valve was closed to remove the toilet and is stuck in the ballcock. worst case you would replace the ballcock. i would try taking the ballcock apart and flushing it out first if it's new enough. if its been in there a while i would just replace it.
Forestland 10-09-2012 05:47 PM
Gurgling noise in toilet
Thanks so much. I'll try this.
Forestland 10-10-2012 02:42 PM
This worked:):):) Thanks again for your help.
Forestland
