Old 12-21-2009, 07:27 PM   #1
DIY Junkie!!
Gurgling sound coming from the base of the toilet
Well, I could start this with "It was a dark and stormy night....", but it isn't. It's just gloomy.....
I just returned to my home after a 5 month absence, working on renovating the old family home in a different state. During that time I left all utilities on and paid all monthly bills so that when I came back home the house would be ready for occupancy.
Now, for the first time since I bought the house in 1994, I have what appears to be a plugged main sewer line. Here are the symptoms:
It all started when I noticed that the tub in the bathroom on the west side of the house was draining slowly enough to build up water when I took a shower. I bought some foaming drain cleaner and tried to relieve the problem.
Then the toilet on the west end of the house refused to flush. When that happened I noticed that water would back up into the tub in the bathroom on the east side of the house. After that, the toilet on the east side started backing up. Obviously a clogged up main sewer line.....
A few applications of a liquid "main line cleaner" had things working well again, until today. The problem didn't begin as before, I had no problems with the shower on the west side of the house, but the toilet there wouldn't drain. I poured some of the "main line cleaner" down the tub drain, hoping to disolve whatever might be clogging the drain line for the toilet, with perhaps some success. The toilet in the bathroom on the east side of the house flushes, although it does seem to be slow.
Now, when I poured water into the toilet bowl on the west side of the house to get some of that "main line cleaner" into the toilet's sewer drain, I hear "gurgling" noises coming from the area where the toilet mates to the flange.
I know that means a new wax gasket, no problem I can do that....but this whole drainage issue has me worried. As long as I have that toilet off, I'd like to address the main sewer line issue.
If it makes any difference, I don't know whether the house's main sewer line, the one leading to the town's sewer system, is on the east side or the west....can I find out at one of the city's offices? The house was built in 1976, perhaps they keep permits on file for that long?
Any suggestions would be gratefully appreciated. I don't mind renting a "rooter" type machine if one is available, just don't want to have to pay somebody to do what I can do for myself! I mean, after all, DIY is what we're all here for, eh ?
Dugly
YerDugliness is offline   Reply With Quote
Old 12-22-2009, 09:35 AM   #2
Sounds like a stubborn drain problem that is doing to take more than any liquid drain cleaner. Your drain may be clogging from roots growing into the drain thus a serious routing would be called for. If you think youre up to it rent a mechanical auger and start from the clean out towards the sewer. If it is roots that should take care of the main problem. If you then want to gently auger from the toilet towards the clean out just to get it clean and free of any corrosion buildup you can do that while the toilet is unseated. Then replace your wax seal and reinstall the toilet. I saw,here on this web site, a great procedure for using 2 wax rings, 1 to "butter" the flange the other for the seal. Here is the link to my blog for this procedure:
http://nationalbuildersupply.blogspo...-wax-ring.html
good luck
faucetman886 is offline   Reply With Quote
Toilet rocks on tile floor Richo Plumbing 18 11-19-2012 01:04 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 02:53 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
