Ground Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2013, 07:14 AM   #1
Ground water
I shut off a toilet in basement i still have ground water seeping up from under my toilet on laundry room floor and hallway.is ther some kind of concrete i can pour to stop this??????
MISSISSIPPI24 is offline   Reply With Quote
Old 04-17-2013, 07:26 AM   #2
Rewards Points: 13,468
Lot more to it than that.
Got to figure out why the waters coming in there in the first place.
Plug that hole and it's just going to find another way in.
Is there at least a sump pump in the basement to relieve some of the water pressure under the slab?
Working gutters, grade running away from the house, no mulch pilled up againt the foundation or flower beds forming pond to hold in water.
Old 04-17-2013, 07:32 AM   #3
Water will win every time, just look at the Grand Canyon.
Have to remove the source or divert it.
Hardway is offline   Reply With Quote
Old 04-17-2013, 07:35 AM   #4
Water backing up thru sewer line had check valve put in.sewers around here not big enough to hold rain when it pours check valve helped but the ground water keeps coming in under the toilet i am wanting to know how to seal the whole thing up?
Old 04-17-2013, 08:32 AM   #5
Is this on a septic tank?
If it's sewer water and not ground water then it sure sounds like your leach field has failed.
Old 04-17-2013, 11:10 AM   #6
Not on septic tank city sewer--all i want to know is there a mix of concrete or anything else i can plug the hole with?
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Adding ground to electric water heater tadc Electrical 8 03-05-2012 08:14 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
