Grohe Shower Head Came Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2012, 01:57 PM   #1
Rewards Points: 87
Grohe shower head came off
Hello all!
I recently purchased as new home with a lovely shower.
While I was taking my 2nd shower, I noticed the water was drizzling again the wall. When I adjusted it, it came off in my hands and I was left with a hard flow from the pipe.
When I took it apart, I noticed the "O" ring was not fitting properly and I suppose there's a screw that holds it in.
I tried to get the "O" ring back in but it was impossible 'cause it was stretched out.
Can any of you confirm that sounds like what the problem is? When I was doing my research, I found the model number Grohe Movario.
Thanking you advance.
momof2labs is offline   Reply With Quote
Old 12-26-2012, 02:24 PM   #2
Rewards Points: 13,300
Shower heads come with tapered threads that match the tapered threads on the pipe coming out of the wall with no O ring needed.
Sure it's not the swivel part that broke off instead?
I've never seen a shower head that used a screw to hold it on.
Some bathtub faucet have screws.
Old 12-26-2012, 06:56 PM   #3
Rewards Points: 87
Hi again:
The shower head came off when I adjusted it wondering why there was so much water running down the side of the wall instead of thru the shower head. Then I looked at the shower head and the swivel part came apart. That's when I noticed the "O" ring wasn't fitting properly.
It may well be the swivel part isn't working. How does it stay attached to the wall cylinder if not by a screw?
I am sorry I can't be more specific. I left the nozzle in the garage which is 150' away and since it's pouring, I don't want to go to get it.
Thanks for your time!
Old 12-26-2012, 07:01 PM   #4
DIY staff
Rewards Points: 7,174
Let me see if I can pull up a PDF on that model---Grohe is a fancy and well made unit----
And a bit complicated---give me a few minutes----Mike----
Old 12-26-2012, 07:06 PM   #5
DIY staff
I googled thar 'movario' it had many different shower heads as options---could you describe the one you have or post a picture?
Old 12-26-2012, 07:09 PM   #6
DIY staff
Is it similar?
Old 12-28-2012, 02:10 PM   #7
Rewards Points: 87
Thumbs up
Originally Posted by oh'mike View Post
Is it similar?
Hi
Yep, this is exactly the one. Thanks.
Old 12-28-2012, 04:15 PM   #8
Rewards Points: 1,458
Grohe is a great company to deal with.
If you call their US number, you'll find that they will b happy to help you work through ANY problem, and will send out any needed part/s gratis.
Been there, done that.
ktkelly is offline   Reply With Quote
Old 12-28-2012, 05:21 PM   #9
Rewards Points: 87
Yep. I was so excited to take a shower in my beautiful new bathroom.
Thanks for the info.
The Following User Says Thank You to momof2labs For This Useful Post:
oh'mike (12-28-2012)
Tags
grohe movario nozzle head , nozzle head
Broken shower head extension (soldered joint) - please help! Simon96Taco Plumbing 24 07-03-2012 03:05 PM
LOW Pressure on Shower - Need head suggestions! LordX Plumbing 5 06-02-2012 02:08 AM
High pressure Shower Head Carloscda Plumbing 9 06-18-2010 01:50 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
