-   -   Grohe shower head came off (http://www.diychatroom.com/f7/grohe-shower-head-came-off-167410/)
momof2labs 12-26-2012 12:57 PM
Hello all!
I recently purchased as new home with a lovely shower.
While I was taking my 2nd shower, I noticed the water was drizzling again the wall. When I adjusted it, it came off in my hands and I was left with a hard flow from the pipe.
When I took it apart, I noticed the "O" ring was not fitting properly and I suppose there's a screw that holds it in.
I tried to get the "O" ring back in but it was impossible 'cause it was stretched out.
Can any of you confirm that sounds like what the problem is? When I was doing my research, I found the model number Grohe Movario.
Thanking you advance.
joecaption 12-26-2012 01:24 PM
Shower heads come with tapered threads that match the tapered threads on the pipe coming out of the wall with no O ring needed.
Sure it's not the swivel part that broke off instead?
I've never seen a shower head that used a screw to hold it on.
Some bathtub faucet have screws.
momof2labs 12-26-2012 05:56 PM
Hi again:
The shower head came off when I adjusted it wondering why there was so much water running down the side of the wall instead of thru the shower head. Then I looked at the shower head and the swivel part came apart. That's when I noticed the "O" ring wasn't fitting properly.
It may well be the swivel part isn't working. How does it stay attached to the wall cylinder if not by a screw?
I am sorry I can't be more specific. I left the nozzle in the garage which is 150' away and since it's pouring, I don't want to go to get it.
Thanks for your time!
oh'mike 12-26-2012 06:01 PM
Let me see if I can pull up a PDF on that model---Grohe is a fancy and well made unit----
And a bit complicated---give me a few minutes----Mike----
oh'mike 12-26-2012 06:06 PM
I googled thar 'movario' it had many different shower heads as options---could you describe the one you have or post a picture?
oh'mike 12-26-2012 06:09 PM
Is it similar?http://db.grohecatalog.com/media/pro...l/E28521US.jpg
momof2labs 12-28-2012 01:10 PM
Originally Posted by oh'mike (Post 1080144)
Hi
Yep, this is exactly the one. Thanks.
ktkelly 12-28-2012 03:15 PM
Grohe is a great company to deal with.
If you call their US number, you'll find that they will b happy to help you work through ANY problem, and will send out any needed part/s gratis.
Been there, done that.
momof2labs 12-28-2012 04:21 PM
Yep. I was so excited to take a shower in my beautiful new bathroom.
Thanks for the info.
