Old 03-01-2008, 12:10 PM   #1
Grinder pump venting
can anyone provide me with a picture of how to properly tie vent line , to grinder pump? new basement bath, need to install pump, not sure how to tie 2" vent line into pump line so as to not have waste pushed into vent. also do I need a back flow valve? thanks
big daddy-o is offline   Reply With Quote
Old 03-01-2008, 01:59 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It should have it's own vent separate coming off the pit and vent to outside on it's own. Two line out the pit, one is vent other is discharge.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-01-2008, 03:30 PM   #3
Electrician
Did you read the directions that came with the pump setup?
chris75 is offline   Reply With Quote
Old 03-01-2008, 05:07 PM   #4
Your pumped line should have a check and shut off valve installed above tank. So when you need to change out your pump you can shut off your valve and your check will hold back all of the fun stuff in your discharge line.
Run your vent to any of your vents upstairs, not to your drain discharge.
Fitter is offline   Reply With Quote
Old 03-01-2008, 06:35 PM   #5
I don't have the pump yet. so no direction reading. the house was built5 yrs. ago and set up for this . vent is stubbed through the floor, I need to bring it down to pump, just not sure of correct way.
Old 03-01-2008, 07:23 PM   #6
Old 03-02-2008, 08:45 PM   #7
so how far into crock does vent pipe go? it 's just venting the crock , correct?
Old 03-02-2008, 09:54 PM   #8
Yep, just off the top.
sump pump issue mikehende Plumbing 15 02-15-2008 07:36 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Grinder pump info big daddy-o Plumbing 3 01-13-2008 12:03 AM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
