Grinder / Ejector Pump - Vent To Side Of House? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2009, 02:46 PM   #1
Grinder / Ejector Pump - vent to side of house?
So, thanks to all the help I received here I was able to convince the builder / plumber to run a dry vent line from the grinder pump for me and no longer wet vent back into the plumbing discharge line! My question now is, they are only agreeing to run it to the side of the house and not up through the roof. Is this normal? Will my yard have odors because of this? Will odors come in through the windows nearby in the summer? Thanks again!
dadruz is offline   Reply With Quote
Old 01-14-2009, 03:35 PM   #2
Check with your local building services dept at the city. That's not acceptable where I am. There's a reason the vents are out the roof. Sounds to me like this guy is trying to screw you.
Reilley is offline   Reply With Quote
Old 01-14-2009, 03:57 PM   #3
Thanks for your feedback, I will check with the local town on that code. When I asked the plumber about it, he said that "Venting to the side of the house meets code in Saratoga County, NY, most houses do it that way, and I should not get odors."
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Ridge vent leaking? Or what? Whatever1 Roofing/Siding 10 09-25-2008 06:24 PM
Problem with whole house fan and not enough attic/roof vent area keeena Roofing/Siding 11 06-16-2008 11:59 AM
Permanently closing an air vent in the house cougar91 HVAC 2 05-17-2008 06:29 AM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
