Grey ( Poly ) To PEX Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2010, 05:58 PM   #1
KD1
Rewards Points: 14
Grey ( Poly ) to PEX connections
Hi, I have a 20 yr old house with what I assume to be the grey Poly plumbing. I want to plumb in a 1/2 bath in the basement and have no trouble getting a cold pipe into which I can put a Poly to PEX adaptor, however, the Hot water is another story. It looks like I will have to cut a Hot pipe in two, and put in a TEE to get the feed to the wash basin. My problem is that so far I can't seem to locate a Tee, which will allow the connection between the two grey Poly pipes but have a PEX acceptable outlet so that I can run it to the new sink. Is there such a thing and if not, is there any way around this? Many thanks in advance for your help!
KD1 is offline   Reply With Quote
Old 05-31-2010, 07:39 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Shark bite T will work. All the big box stores carry them.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 05-31-2010, 07:54 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I assume by poly you mean PB pipe. If you do not want to use the Sharkbite. Cut a 12" section out of the PB, use 2 PB to PEX adapters with a 1 foot section of PEX to reconnect. Cut the PRX in half and put in a PEX tee.
Coastal South Carolina
Old 05-31-2010, 08:04 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'd be more apt to using the sharkbite tee. Those polybutelene fittings and crimp rings and pipe are known to fail... why put in another one thats bound to fail anyway?
Journeyman Plumber
Alan is online now   Reply With Quote
Old 05-31-2010, 09:15 PM   #5
KD1
Rewards Points: 14
Many thanks for all the replies. So far all the crimp connections have served me well, so I have no worries on that front. I think the two PB to PAX adaptors running into the PAX 12" + Tee, sounds like a good plan ( Never thought of that! D'OH!)
Again, many thanks Guys!
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 07:29 AM
Stain over Poly? megkatgre Flooring 3 04-27-2010 12:07 PM
Using white thinset with dark grey grout. sukhenkoi Tiling, ceramics, marble 5 04-20-2010 06:54 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
Poly interior doors gregrice Painting 4 05-15-2006 12:35 PM
