Greetings From Canada... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2008, 08:18 PM   #1
Rewards Points: 14
Greetings from Canada...
Good Readership...
I have, in my basement, a 1/2" copper n.g. line feeding a gas f.p. on the main floor. It is convenient to the area where I'd like to install a n.g. stove as part of a basement kitchen. Can I "T" off this 1/2" line a run more 1/2" copper a short distance ( about 5' in total ) to the range? The 1/2" feed originates about 25' away. The feed from the meter is 1" black pipe, it feeds a gas furnace & gas water heater right where it enters the house; I've already T'd off of this pipe to supply my bbq. ( about 25' of 1/2" copper ), the previously mentioned main floor f.p., & a 3/8" line ( 18' ) feeding a soon-to-be-installed basement gas f.p.
I appreciate your input folks!
Regards,
DSD
DeepSeaDan is offline   Reply With Quote
Old 02-28-2008, 09:38 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Dan,
That may be something that you can get done free by your gas company. Have you given them a call about it?
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-28-2008, 05:01 PM   #3
Rewards Points: 14
Hello Mike...
Originally Posted by Mike Swearingen View Post
Dan,
Mike
...I can't see this as being anything to hire a gas-fitter to do, they'd charge a bundle! I've worked with lots of plumbing before & am comfortable doing the install, it's just a code compliance issue.
I'll have to go to the local Home Depot & ask, they usually know the local code requirements for the area.
Thanks for the response.
DSD
Hi! from Vancovuer Canada! mrmac204 Introductions 2 12-04-2007 04:34 AM
Greetings from Ontario, Canada! hamiltonian Introductions 3 05-10-2007 07:09 AM
Where the heck is Canada woodmagman Introductions 4 04-17-2007 04:12 PM
Hello from Toronto, Canada mcvane Introductions 15 03-28-2007 02:33 PM
