Greenish White Chunks Clogging Faucet Aerator - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 07:54 PM   #16
Licensed Master Plumber
Change the faucet. It is cheap brass in the faucet that is de-zincafying. A combination of water conditions and flow volume cause the brass to break down. When it does there is a white powder ( zinc mostly ) that scrubs off and clogs your faucet. Moen.....strikes again
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 05-14-2010, 10:38 PM   #17
Water quality'n pump guy
The vinegar test will tell what it is; fizz means hardness.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 05-15-2010, 07:12 AM   #18
Posts # 13 & # 14
They don't fizz they float.
Old 05-15-2010, 12:27 PM   #19
Posts # 13 & # 14
For some reason I didn't see that.
Then since it floats it's not brass corrosion.
Gary Slusser
Old 05-16-2010, 09:25 PM   #20
Rewards Points: 2,638
Originally Posted by Studly View Post
I tried melting these chunks with heat and they do not melt, as plastic would.
I don't know what they use for dip tubes, but I know a little about plastics. There are two main categories for plastics. The first is called "thermoplastics" like polyester that soften and melt when you heat them and then harden when you cool them.
The other category is called "thermosetting" like epoxy and bakelite. Once it sets, heat will not melt it. It will eventually fall apart if taken to too high a temperature, but will not melt.
So just because heat does not melt it does not mean that it is not plastic. And if you think about it, if you were going to put a piece of plastic into hot water for 10 years, a thermosetting plastic might what they choose.
SPS-1 is offline   Reply With Quote
Old 07-08-2010, 02:56 PM   #21
Just fiddlin' with it.
Lightbulb
Maybe a solution.
Hi,
First time poster. I found this forum while trying to find a solution to the same problem. Since I didn't find an answer at the time, I moved on.
But now, thanks to my Dad, I might have an answer. He gave me a supplement insert he got in Popular Mechanics and there was a Q&A with this very question. According to their answer, the blue-green-white chunks are aluminum hydroxide caused by a high (8+) pH in the water reacting with the aluminum anode. They say replacing the aluminum anode with a magnesium one will fix this.
I searched their site and did a general Google search and could only find this article (nothing on PM site).
http://www.hot-water-heaters-reviews.com/anode-rod.html
Good luck and hope this helps.
GunSgt1863 is offline   Reply With Quote
Old 07-08-2010, 03:03 PM   #22
Rewards Points: 229
Thanks again everyone for the advice. As it turned out, the Moen faucet was causing the problem. Once I replaced it, no more problems. Even though it was only about 5 years old, I removed the faucet that was getting clogged, pulled it apart and saw some severe rusting and corrosion on the inside of the faucet. I didn't cut it apart to inspect the inside tubes on the faucet, but the outside of the tubes was really bad so I'm sure it was on the inside too.
I wasn't happy that this new of faucet was already that rusted/corroded (we have big city treated water with no iron in it), but was pleased with Moen's customer service. They sent a new one for free to replace it, since it has a lifetime warranty, and the problem is solved.
Everyone says Moen has a great warranty, great customer service and backs their products, and I see why now.
Studly is offline   Reply With Quote
Old 07-08-2010, 04:55 PM   #23
Thanks for letting us know and glad to hear you fixed the problem. Contrary to Mr. Slussers post which I am sure he will continue to argue, Moen faucets are prone to that particular problem. Those of us that do a lot of plumbing service run into it all the time.
Old 07-11-2010, 11:28 AM   #24
Rewards Points: 352
Thank You for sharing your experience, I believe your education cost more than a college degree
plumberinlaw is offline   Reply With Quote
turquoise sediment clogging aerator poger67 Plumbing 2 01-04-2010 08:28 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Aerator for Hose Faucet prowler 13 Plumbing 2 12-17-2007 07:17 AM
