Green Stuff On Shower Valve Connections I Put In..need A Little Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2010, 04:22 PM   #1
green stuff on shower valve connections i put in..need a little help
renovating my downstairs bathroom and i put in the new shower valve. it's been a month and i'm getting around to putting in the shower and tub trim kit. i took a look through the hole at the valve and i noticed that green material has accumulated at all four connections where i sweated the copper pipes into the valve. is this a serious problem? what causes it? is it a water leak somehow? do i need to rip it out and have it redone?
doo42 is offline   Reply With Quote
Old 08-03-2010, 05:38 PM   #2
The green stuff is most likely flux residue. This occurs when the joint is not properly wiped with a rag.
jc60618 is offline   Reply With Quote
Old 08-03-2010, 11:40 PM   #3
^ what he said
fhrace is offline   Reply With Quote
Shower valve rough-in mpt1123 Plumbing 16 12-24-2015 01:51 PM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Shower Valve Destroyer ? Help! doneitnow Plumbing 2 05-05-2008 10:15 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
