Old 05-08-2012, 04:27 PM   #1
Grease trap requirements and codes
Where can I find the documentation or codes for a grease trap installed in a deli? We have spent too much money trying to make the changes and we are continually told there are more changes to to be made. Thousands of dollars fixing and now we are being temporarily shut down for business at the beginning of our busy season. Where can I look for rules, regulations, specs, etc?
Kim Scheu is offline   Reply With Quote
Old 05-08-2012, 04:29 PM   #2
You need to go back and edit your profile so we will know what rules apply.
Every state and even countys can be diffferant.
Old 05-08-2012, 05:49 PM   #3
MarginallyQualified
The County doesn't hide their requirements.
The plumbing dept will be happy to tell you the specific requirements...
have you asked *them* ?
Then get it put into writing.
Then speak with a good plumber about once and for all doing what's required.
There are also OTHER options to meet the code as well.
http://www.igrd.com/
hth
TarheelTerp is online now   Reply With Quote
The Following User Says Thank You to TarheelTerp For This Useful Post:
TheEplumber (05-08-2012)
Old 05-08-2012, 09:58 PM   #4
Master Plumber
Javiles's Avatar
Depending on your location and store setup you may be in for a hell of a nightmare. Here grease traps requirements are set up and controlled by DERM,, Department Environmental Resources Management… Installation permits operating permits etc, monitoring and maintenance logs, post your location will try and help.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Natural Gas Grill Code Requirements adpanko Plumbing 13 05-16-2012 02:03 PM
Do Indoor Dryer Vents meet safety codes in Alberta (Canada) maneatingcow HVAC 4 09-23-2011 11:30 AM
Reroofing code requirements beerdog Roofing 3 08-08-2011 11:03 PM
Building codes for stairs in MA schh4 Building & Construction 2 07-19-2010 08:29 PM
