Grease Trap Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2014, 07:28 AM   #1
Grease trap installation
I bought a grease trap, but there were no instructions. I just have two questions. 1) Which in the inlet and which is the outlet. I assume the top opening is the inlet, but I am not sure. 2) Which way does the basket go in, does the open side point towards the top opening, or the bottom.
Thanks.
portbarton is offline   Reply With Quote
Old 07-12-2014, 10:01 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Inlet is the high pipe, outlet low. Open side of basket toward inlet.
That is a small unit, it should probably can only serve a single sink. Grease traps are rated by the gallon flow rate.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 07-12-2014, 01:56 PM   #3
Rewards Points: 1,684
I gather they allow none plumbers to do commercial plumbing in your area? That is strictly forbidden in Ohio.
A state licensed plumber would need to pull a permit. A plan would need to be submitted with sizing information and venting requirements. Also the Grease trapped once sized for your sinks would need to be PDI approved if even allowed. Since food joints apparently have a problem with cleaning them weekly and disposing of the grease properly quite a few sewer providers are not allowing interior grease interceptors. They seem to prefer the outside ones that have pumping records and a test pit to make sure you are cleaning it.
You may ask why I will have to tell you a little story about a Chinese food restaurant that had interior grease traps that were never maintained. They managed blocking the cities sewers with rice and huge chunks of white grease. In the end it cost the sewer department about 35 grand to clean. They traced it all back with cameras and sent the food joint the bill. Then required he install a 1500 gallon outside interceptor.
Goggle grease in main sewers for some great pictures.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
jmon (07-12-2014), TheEplumber (07-12-2014)
Old 07-12-2014, 02:01 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
Do you have a flow restrictor? How about venting?
Trap help for bathroom sink Trucon01 Plumbing 8 04-14-2014 06:00 PM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 06:45 PM
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 07:42 PM
p trap problem chrishulett Plumbing 8 01-28-2011 06:52 AM
Hepvo trap for shower? lee12 Plumbing 4 01-20-2011 09:11 PM
