Gravity Hot Water Recirculating Loop Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2007, 07:41 AM   #1
Rewards Points: 150
So I have to wait too long for hot water. I've been looking at recirculating pumps, various brands, various methods. Read and article about gravity hot water recir. loops. I understand the theory, but am wondering if two loops can work.
Info I read is here:
http://www.askthebuilder.com/147_Gra...ng_Loops.shtml
Cliffs on info:
You run a return hot water line from furthest fixture. You plumb it into the hot water heater's drain spigot. You remove any backflow preventer on the hot water supply side. Thermal properties of heated water take over and hot water rises out of HW heater and the cooler water in the return lines "sinks" into the bottom of your water heater. This slow circular motion keeps hot water available at furthest point. You must insulate the lines, except for last 15ft of return.
So my water lines look like the below diagram, but I would like Hot water at both ends of the line, and am wondering if two loops would work, and if so how to plumbe them correctly.
harleysilo is offline   Reply With Quote
Old 01-17-2007, 08:37 AM   #2
Rewards Points: 150
So I found another article...
http://www.contractormag.com/article...fm?columnid=62
Main thing I picked up on is it states I should add the volume of water now contained in the loop to my calculation for the expansion tank size....
So for me one loop of 100' of 3/4 would be approx....5 gallons.....
Old 02-06-2007, 03:28 PM   #3
There are different models but they do the same thing. It pumps the water back into the cold water supply line until there is hot water at the fixture.
http://www.costco.com/Browse/Product...&Mo=11&topnav=
redline is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Gravity hot water loop for instant hot water at tap ricgail Plumbing 4 11-17-2006 04:59 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Recirculating hot water KTMMIKE Plumbing 10 09-07-2005 03:04 PM
