Gravity Hot Water Loop For Instant Hot Water At Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2006, 08:02 AM   #1
Gravity hot water loop for instant hot water at tap
Was reading an old thread and I have an additional question. I installed a gravity loop with a check valve in the basement of my house and the far end at the furthest tap. It does not appear to be working and I was wondering if I should install an inline pump and put it on a timer or is there a pressure sensing differental pump that could be installed. It would come on when a hot tap is turned on anywhere in the house which would place hot water out to the furthest tap????? Am I thinking correct and if so what pump or pumps could be used and what would the costs be?
ricgail is offline   Reply With Quote
Old 11-16-2006, 04:50 PM   #2
What you need is a circulating pump. This keeps hot water flowing through the line at all times. Another option is a pump that has a demand switch. When you need hot water, you hit the switch and the pump kicks on and circulates the hot water. This idea keeps from having a pump running all the time.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-17-2006, 08:03 AM   #3
Have you put pipe insulation on the pipe?
redline is offline   Reply With Quote
Old 11-17-2006, 09:08 AM   #4
Gravity hot water line
Which line needs to be insulated? the return loop or the main line?
Old 11-17-2006, 04:59 PM   #5
Insulating any hot water line that is circulating water will save energy and money. The line going back to the water heater causes the temperature in the tank to drop and force the heating source (electric/gas) to energize to maintain the preset temperature of the unit.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
