Gravel In My Water Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2012, 02:43 PM   #1
Gravel in my water pipes
I've always noticed that our water pressure throughout our (one year old) house is on the low side, and our fridge's ice maker sometimes makes small cubes. When I was replacing one of my faucets (because it wouldn't shut off), I found small gravel at the head of the pipe. The same type of gravel that's in our crawl space. I think the plumbing contractor got gravel into our lines when the house was being built.
Question: How do I remove the gravel that's obviously there? Do I have to remove all the fixtures and purge the lines? Do I have to find the low spot in the plumbing, cut the line, and blow out the lines with air pressure? I'm really at a loss on how to fix this problem. (the plumber is out of business, no surprise).
attainedage is offline   Reply With Quote
Old 02-22-2012, 05:08 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh.... Are ya on a Well,..??
If not, have you checked the pressure that's bein' delivered,..??
If it's Severe, I'd think pullin', 'n purgin' might be needed...
Bondo is online now   Reply With Quote
Old 02-22-2012, 08:54 PM   #3
Rewards Points: 346
It's possible that the gravel is coming from the well water supply.
Could be your holding tank, if the bladder is going soft or bad, gravel can sneak in to the water lines.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 02-22-2012, 09:20 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
To answer your question, you would have to have the system back flushed, couple ways of doing it. I do not Recommend DIY . And not all plumbers know how to do it correctly, you’ll need to check around to find someone with experience in this area. You also need to track the source of the gravel. Good luck
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-23-2012, 01:32 PM   #5
Gravel in pipes
Thank you, Javiles. We're not on a well. The house is less than two years old. The gravel is the same pea gravel that's in our crawl space. I suspect that the plumbers who did the plumbing didn't tape their pipe ends as they were feeding them into the crawl space, and of course, that's where the rocks came from. I will talk more to my general contractor about back flushing.
Water Pipe Protection for Underground Pipes ArtCTNY Plumbing 3 06-22-2011 05:37 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Hot Water Pipes Making Noise kubichekb Plumbing 2 02-12-2010 10:41 AM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
