Grate Drain At Bottom Of Steps - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2011, 02:08 PM   #1
Grate Drain at Bottom of Steps
I want to put the grate drain at the bottom of the steps where the blue square is located. The grate drain is 5 inches deep. My footer is 6 inches deep. I do not want to go under my footer. Can I notch out a part of the footer (yellow circle) to connect to the drain tile? Or will that cause a structural issue. The reason is water runs down the step during heavy rainfall. I am using 4 inch perforated pvc.
sloojoe is offline   Reply With Quote
Old 05-03-2011, 03:39 AM   #2
When you say 'notch out', do you mean 'go through'?
Are you tying into a drain tile on the other side of the footer?
It would not be advisable to punch through the footer, nor would it be possible without something like a core drill. ..and even then, if there is rebar.
Robo_geek is offline   Reply With Quote
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 05:23 PM
What's Needed for Drain Tile / French Drain samsmith Building & Construction 2 08-24-2010 12:20 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
