Granite Stain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2010, 07:14 AM   #1
Granite stain
New bathroom faucets said to use plumbers putty. It stained the granite top. I removed the putty and the stain and started over. Second time I used silicone caulk. But it also stained the granite...it made dark circles around the faucets. What now?
Robert A is offline   Reply With Quote
Old 01-20-2010, 03:25 PM   #2
BIGRED
Rewards Points: 252
To avoid this same problem on granite or any natural stone surface I was always told not to use any oil based sealant when installing any fixture on these types of surfaces. Problem is how to seal the fixture penetration through the stone. Get yourself some 1/8" thick foam padded two-sided tape, or some 1/4" foam rubber (no sponges), or foam wind seals for electrical outlet covers and make yourself a seal that is the same size as the fixture escutcheon. Then mark the exact center of your seal and cut a hole the same size as the fixture penetration -not the hole-. Put the pieces together,
tighten everything up and you will have a water-proof non-staining seal for any natural stone surface.
Grampa Bud is offline   Reply With Quote
Old 01-25-2010, 02:47 AM   #3
or buy a porous approved plumbers putty made by hercules
fhrace is offline   Reply With Quote
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 11:49 AM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 08:58 AM
granite countertop stain? Is there anything that can be done? MrLinux Remodeling 4 02-13-2008 08:52 AM
